[APP][Pro][Test] Energy Price Forecast – electricity prices, grid CO₂ and smart planning
Hi everyone,
The HomeyScript prototype from this forum has grown into a native Homey app. Energy Price Forecast 1.0 is now available in Homey’s Test channel. The normal setup no longer requires HomeyScript or Advanced Flow.
Install the Test app:
What the app does
The app adds a virtual forecast device with:
  • the current electricity price and current grid CO₂ intensity;
  • official day-ahead prices whenever available, with forecast values filling only the remaining horizon;
  • the cheapest continuous price window and the greenest CO₂ window;
  • the cheapest N individual hours inside each fixed X-hour block, intended for heat pumps, boilers and other loads that must run regularly;
  • a weekend charging plan for EVs;
  • visible data source, forecast horizon and freshness status;
  • Flow triggers and conditions for starting and ending plans, price/CO₂ windows, data freshness and failures.
The fixed-block heat-pump logic is deliberate: it prevents the app from always choosing a cheaper hour on the following day and postponing heating indefinitely.
Free and Private Pro
  • Free: no account or API key required, with a forecast horizon of up to 48 hours. Weekend charging plans Saturday 00:00 to Monday 00:00.
  • Private Pro: optional API key, with a horizon of up to 120 hours and the ability to prepare the weekend plan from Friday.
Private Pro is optional. The app and its core planning features remain usable without it.
Supported Homey platforms
This first Test release supports:
  • Homey Pro;
  • Homey Pro mini;
  • Homey Self-Hosted Server.
Homey Cloud is not supported in this first release because publishing a cloud-compatible app requires an additional verified-developer step.
The app is currently in the Test channel and is not yet Homey-certified. Homey will show the corresponding warning during installation.
Markets and pricing
The app currently covers Germany, the Netherlands, Belgium, France, Austria, Czechia, Poland, Finland, Sweden (SE1–SE4), Denmark (DK1–DK2) and Norway (NO1–NO5).
Base market prices are available across these markets. Retail estimates are available for selected markets and may require a postcode. Forecast and retail values are estimates and can differ from your supplier’s final bill.
Privacy
The app requests only the information needed for the forecast: selected market, currency, horizon, pricing mode and—when retail pricing requires it—the postcode. An optional API key is sent as an authorization header. The app does not send Homey device lists, Flow contents or household consumption data to Energy Price Forecast.
Feedback that would help most
If you test it, please mention:
  1. your Homey model and country/price area;
  2. whether pairing and the setup explanations were clear;
  3. whether the heat-pump or weekend plan changes at the expected times;
  4. whether the Flow cards start and end reliably;
  5. any status value or number that looks wrong.
Screenshots are welcome, but please hide your API key and any personal information.
More details and installation guidance:
Thanks again to everyone who helped test the earlier HomeyScript version.
When adding the device the error appears: Error: Could not load script: /js/homey.pair.js
@Fred_Hartmann Thanks for the feedback.
Should work now. Pleas try again. Would be happy to here from you.
Hi Hendrik,
Unfortunately still an error: “Error: Could not load script: /js/homey.pair.js” (Homey pro 2023)
Greetings, Fred
@Fred_Hartmann Hi Fred,
Thanks for testing again — and sorry for the trouble.
Could you check which version you have? Settings → Apps → Energy Price
Forecast shows it. I only pushed the fix a few minutes before your
message, so there’s a good chance your Homey was still on 1.0.0.
The fix is in 1.0.3. If you’re on anything older, you can force the
update by opening the test link again:
What changed: the pairing page was loading /homey.js, which then tries
to pull /js/homey.pair.js. That script tag is gone — the page no longer
loads any external script at all.
If you’re already on 1.0.3 and it still fails, two more questions, and
then I’ll know where to dig:
  1. Are you using the Homey mobile app, or the web app in a browser?
  2. Does adding a device work for other apps that have their own setup
    screen? (Anything that asks you for an IP address, a login or a
    region while pairing.)
That second one matters: since 1.0.3 the page requests no scripts of its
own, so if the error persists, it’s Homey’s own pairing container asking
for that file — and knowing whether other apps hit it too tells us
whether this is my app or something on your Homey.
Thanks for sticking with it.
Hendrik
Ok, installation was succesfull. App was not automatic updatet to 1.03..
thank you!
Hi Hendrik,
I’m experiencing an issue with Energy Price Forecast.
My setup:
  • Homey Pro 2019
  • Homey firmware 13.5.3
  • Energy Price Forecast app 1.2.1
  • Sweden (SE3)
  • No API key (using the free 48-hour mode)
When adding the Price & CO₂ Forecast device, I get:
“Forecast API timed out.”
I also tested the API endpoint directly in a browser. It returns:
{"detail":"Forecast-Datenquelle antwortet nicht rechtzeitig. Bitte erneut versuchen."}
I waited another 24 hours and tested again, with exactly the same result.
Could you check whether the forecast data source is currently working for Sweden, and whether there is anything else I can do to troubleshoot this?
Thanks!
Hi Oskar,
thank you for your high quality Feedback. SE3 API ist offline at the Moment, sorry. I will fix it tonight wegen the Kids are sleeping.
Best regards Hendrik
It should be working again now. Unfortunately, due to licensing restrictions, I can no longer publish actual electricity prices for SE3 and other regions.
I’m working on a solution that combines actual prices (retrieved by users themselves) with the forecasts.
Best regards,
Hendrik
The Update with the combined tarrifs is now in testing. I would be happy about your Feedback.
