[APP][Pro] Qolsys IQ
Access and control via local connection your QolSys IQ alarm system.
I’ve tested this on my own Qolsys IQ Pro panel - but have no hardware to test it on other systems :wink:
Hello @alistair, thanks for a great app! I have just installed a new home alarm with a IQ Panel 4. I succeed to pair my IQ Hub to Homey through your app and it works to arm/disarm etc. But after about 15 minutes the Homey-connection to the hub dies.
From what I understand I should use the “secret token” in my hub (after activating Control 4). But when pairing the IQ Hub in Homey I never get any request to enter the secret token, I can’t either find anywhere to enter it after installation. I think this is related to why the Homey connection dies, since the IQ Hub gives 15 minutes to finalize the pairing before deactivating Control4 again. If I’ve not completely misunderstood it all..
Could you give any clarification about this?
Thanks a lot in advance!
I found the solution to this with help from my swedish retailer - Protexus. I never needed to activate “Control4”, my connection died after 15 minutes because of that I activated this before the paring with Homey.
Now the Homey-integration works perfect :partying_face:
The last couple of days my IQ Hub (Qolsys-app) as lost connection in Homey. At first I thought it was my IQ Hub that had lost the connection to Homey, but after a simple restart of the Qolsys-app in Homey, connection was restored and everything was working as normal again.
This have happened a couple of times the last days. Since everyhing works fine just after a restart of the app, it doesnt seems to be any issue with the actual connnection to the IQ Hub, but rather something with the Qolsys-app?
I am experiencing the same problem. It works flawlessly for days and then it dies. Just restarting the Homey app solves the issue. Yesterday I set static IP on both Qolsys and Homey and today it lost connection again. :pensive_face: The app is so great and powerful that I really want it to work. Did you ever solve the issue?
It has worked perfect for me the last months. Maybe one or two “connections lost” but overall, no problem. I have a Deco mesh-network and what I did is that I locked the IP for IQ Hub in my Deco router, and also locked it on 5Ghz + locked it on the closest mesh hub. In that way it doesn’t jump between 2,5Ghz/5Ghz or between different mesh hubs. Since this, it has worked almost 100%.
I love this app and to be able to integrate my home alarm in Homey, I have made many really useful flows that for example sets “Armed away” automatically when all persons have left the house etc. Absolutely love it!
