@Arie_J_Godschalk
The upload of snapshot work to synology FTP but i discovered something else…
The last field is obligated and it seems that this is the filename which is used for saving.
This is good, but sadly this is not dynamic, this means that the saved file is overwritten each time your run the flow.
I wanted to use the time card to make the file name dynamic but that had a very strange effect on the filename on the server itself. For example:
So what i want to request is (if possible):
- if field ‘path’ (last field in card) is left blank (at the moment you must fill this in) use then the filename which is used by the snapshot card itself, i noticed in your former replies that this name was an (unique) id, so this is dynamic!
or/and - add flow tag to choose unixtimestamp (or seconds) which you can use as name: <tag_unixtime>_xxxxx.ext this would result in saving in my example something like: 123457_deurbel.jpg or seconds <tag_seconds>xxxxx.ext would result in filename: 56deurbel.jpg etc
[offtopic]I requested in the past in other topic the usage of a seconds tag card (beside time card) and this is one of the example where such second (or unix) card could/would become very handy…[/offtopic]
Maybe you or someone else has even a better idea to save the snapshot with a dynamic name to prevent overwriting?
