Eurotronic Technology Z-wave app
This app adds support for Z-Wave devices made by Eurotronic.
Links:
Athom app-store
Test Athom app-store
Github repository
Supported devices:
Eurotronic Stella
A Z-wave based thermostatic.
To be able to control them, it will have to wake up every time you send a command.
This will happen automatically every 1 hour (changeable) or you can activate it manually.
Capabilities:
- Read battery level
- Read measured temperature
- Set & Read target temperature
- Set economic temperature*
- Set & Read working modes
- Manual valve position**
*= These are only configurable with flow cards.
**= These are only configurable with flow cards in Homey v1, v2 it will have it’s own screen.
Eurotronic Comet
Capabilities:
Eurotronic Spirit Z-Wave
A Z-wave based thermostatic with FLiRS, making it respond instantly to your commands.
Capabilities:
- Set child protection*
- Set external room temperature**
*= You have the option to lock it fully, or set it unlockable, you can unlock by holding the +
and -
buttons.
**= You will need to activate this behaviour in the device’s (advanced) settings.
Eurotronic Air Quality Sensor
A Z-wave based air quality sensor that measures VOC and CO2 levels besides the room temperature, humidity and dew-point.
Capabilities:
- Read VOC level (ppb)
- Read CO2 level (ppm)
- Read (room) temperature
- Read humidity
- Read dew-point
Eurotronic Temperature/Humidity Sensor
A Z-wave based temperature and humidity sensor.
Capabilities:
- Read humidity
- Read dew-point
Eurotronic Door/Window Sensor
A Z-wave based door window sensor, that doesn’t use a Magnet! but an IR (infrared) distance sensor.
Capabilities:
- Contact sensor
Supported Languages:
- English
- Dutch (Nederlands)
- Deutsche (German)
Feedback:
Any requests or questions you can contact me in this topic, on this Forum or on Slack
If possible, please report issues on Github.
Upcoming:
None Currently
Changelog:
v3.0.1:
- Add support Door/Window Sensor
- Rewrite to SDKv3
- Adjusting behaviour of Spirit thermostat according Athom’s rules
- Homey Bridge Support
v2.3.4:
- Add support Air Quality Sensor
- Add support Temperature/Humidity Sensor
- Add “Deutsche (German)” translation
v2.2.0:
- Official app transfer to Eurotronic Technology GmbH
- Fix Protection status not synchronizing of the Spirit valve
- Add support for the Aeotec Limited boxed Spirit valve
- Update Meshdriver to 1.3.24
v2.1.0:
- Add battery types for Homey v3’s Energy
v2.0.7:
- [Spirit] Fix device’s measured temperature overwriting the external temperature sensor (when used).
- Update meshdriver to v1.3.3
v2.0.6:
[Comet] Fix crash
v2.0.5:
[Stella] Fix crash
[Spirit] (Re)Set measured temperature on change of external temperature setting
Add insights for the manual value
v2.0.4:
Fix the wrong device (last included) being the device always controlled from flows
v2.0.3:
Spirit: Fix not being able to send the room temperature
Added a setting for the Economic temperature
Increased stability for flows
v2.0.2:
Fix rounding errors manual control
Rewritten internal functions making the app more stable (in particular with multiple devices)
v2.0.1:
Fix spirit external temperature setting not set-able
Fix set eco temperature flow card
Update Meshdriver
v2.0.0:
Complete Re-write to SDKv2, making it fully ready for Homey v2.
Update mesh-driver to v1.2.28
v1.2.1:
Spirit: Fix default temperature reporting, normal default is too high.
Spirit: Fix a few text errors.
Spirit: Added id’s for (future) firmware updates of the spirit.
