[APP][PRO] Sensibo
For Sensibo Sky, Sensibo Air, Sensibo Pure and Sensibo Room Sensors.
App store: Sensibo | Homey
To install:
  1. Get an API-key from https://home.sensibo.com/me/api
  2. Set the API-key during pairing of the device
Device: Sensibo
Triggers
  • The target temperature changed.
  • Thermostat mode changed.
  • The temperature changed.
  • The humidity changed.
  • Device turned on.
  • Device turned off.
  • Device offline.
  • Timer created.
  • Timer fired.
  • Timer deleted.
  • AC state changed.
  • Climate React changed.
Conditions
  • Thermostat mode is.
  • Is on.
  • Climate React is enabled / disabled.
  • Timer is enabled / disabled.
Actions
  • Set the temperature.
  • Set the mode (Automatic, Heat, Cool, Off)
  • Turn on.
  • Turn off.
  • Set the fan mode.
  • Set the fan level.
  • Set Swing mode.
  • Set Horizontal swing mode.
  • Control Climate React.
  • Control Pure Boost.
  • Control light.
  • Sync power state.
  • Set timer.
  • Delete timer.
Capabilities
  • On / off
  • Fan level
  • Fan mode
  • Target temperature
  • Swing
  • Horizontal swing
  • Climate React
  • Temperature
  • Humidity
  • Last seen
Device: Sensibo Pure
Triggers
  • Device turned on.
  • Air quality changed.
  • Device offline.
  • Timer created.
  • Timer fired.
  • Timer deleted.
Conditions
  • Is on.
Actions
  • Turn on.
  • Turn off.
  • Control light.
  • Set timer.
  • Delete timer.
Capabilities
  • On / off
  • Fan level
  • Temperature
  • Humidity
  • Last seen
Device: Sensibo Room Sensor
Triggers
  • Device offline.
Capabilities
  • Temperature
  • Humidity
  • Last seen
Release Notes:
1.10.1
  • Added Control Pure Boost action for Sensibo Pure
  • Options for lights (on, off, dim) are now fetched from remote capabilities
1.10.0
  • Added support for Sensibo Pure and Sensibo Room Sensor
1.9.5
  • Added horizontal swing (capability and action card)
  • Added action to sync the power state
  • Added action to control Pure Boost
  • Added action to control the AC light
  • Added fan levels (Medium high, Medium low, Quiet)
  • Fixes for pairing
1.8.0
  • Changed minimum temperature to 10 deg. C
  • Updated to SDK 3
1.7.1
  • Minor bug fix
1.7.0
  • Dynamic list of modes and fan levels when setting from flows
1.6.1
  • Added triggers for timers
V. 1.1.0 with support for swing mode:
Due to the takeover of the app by @OH2TH, all posts have been moved to the new topic [APP][Pro] Sensibo - new maintainer and this topic has been closed.
who can help me with API key for Sensibo device
I can go to the website https://home.sensibo.com/me/api
but have no clue what to do on that page.
I found the solution myself. You just need to eneter device id in the bottom field.
When I want to install two separate Sensibo Sky devices on one Homey, can I use the same API key for both? Or do I need to get one for each device?
Thanks for your post, strange that this is nowhere listed how to do it not even inside homey app for sensibo or on the homepage of sensibo itself.
