Hi everyone ![]()
I’d like to introduce ClimaWise, a Homey app that manages heating and air conditioning room by room. It’s part of my “Wise” family (ShadeWise, AirWise, PoolWise, GardenWise).
[screenshot: the ClimaWise house widget]
What it does
- Rooms, not devices: group the devices of a room (split / heat pump, thermostat, radiator on pilot wire, towel dryer, relay) and pick a real room sensor. ClimaWise corrects the split’s own sensor with it.
- Comfort profiles and weekly schedules: Comfort, Eco, Night, Away, Frost protection, with your own setpoints.
- Automatic season: based on the months, adjusted by the outdoor temperature and the forecast. Never uses the devices’ “auto” mode: it’s always heat or cool.
- Gentle on heat pumps: at setpoint it lowers the target instead of switching off, and keeps at least 20 min between two starts. It also limits cloud commands (MELCloud, Tado, Heatzy…) and doesn’t mistake a slow cloud update for a manual change.
- Windows and doors: pauses after a few minutes, resumes when closed. The door rule can be limited to a time window. Built-in open-window detection (Tado, Heatzy) is respected.
- Presence and vacation: Away when nobody is home, Vacation for long absences.
- Learned pre-heating: rooms are at temperature on time.
- Boost per room (e.g. bathroom 24 °C for 30 min from a button).
- Manual changes respected until the next schedule slot.
- Frost guard per room (“never below 7 °C”).
Energy (all optional, off by default)
- Off-peak hours and EDF Tempo (France): pre-heat in off-peak, −1 °C on red days, heat stored the night before.
- Solar surplus: a small boost when your panels export.
- Forecast sun: less morning pre-heating in sunny rooms.
- Load shedding: pauses towel dryers and radiators first when the house gets close to your contract power.
- Weekly report: kWh per room and comparison at equal weather.
In Homey
- One virtual thermostat per room, so you can use the app, dashboards and voice.
- A House device with season mode, presence mode and “Eco 2 h / Back to schedule” buttons.
- 4 dashboard widgets:
- House: animated scene following the live weather; the heat-pump fan spins when a split runs;
- Rooms;
- Room: setpoint and Boost;
- Energy: today, last 7 days, by room, Tempo.
- Insights charts, many Flow cards, and Homey’s own thermostat cards.
[screenshots: settings page · Room widget · Energy widget]
Safe start
The app is off by default. While it’s off it runs in trial mode: each room shows what ClimaWise would do, without touching any device. A wizard finds your rooms, devices and sensors.
Wise apps link (optional)
If you also use ShadeWise, AirWise, PoolWise or GardenWise, they can share:
- vacation,
- the solar surplus,
- outdoor readings,
- Tempo colours,
- the heatwave / cold snap plan,
- a single daily summary.
Each app decides on its own; nothing is controlled remotely.
Languages
English, French, German, Dutch.
Install
[test version link / App Store link]
Tested at home with:
- Mitsubishi splits (MELCloud),
- a Tado Smart AC,
- Heatzy towel dryers,
- Netatmo and Aqara sensors.
It should work with any brand that exposes a thermostat, a pilot-wire mode or an on/off.
Feedback, bug reports and ideas are very welcome. Please mention your devices, it helps a lot! ![]()
