[APP][Pro] Værmeldingen – The complete weather app for Norway
Værmeldingen (“the weather forecast” in Norwegian) is a complete weather app for Norway. One device gives you the forecast from several weather models, radar nowcast, new snow and snow depth, the risk of slippery roads, air quality, MET weather warnings, MET’s own text forecast and, if you like, the readings from your own weather station. The forecast works anywhere, but the app is made first and foremost for Norway.
Install the test version of Værmeldingen
Why I made it
I used the Værvarsel (Yr) app, but some of its flow card problems have been reported in its forum topic for a long time without being fixed:
  • Tags such as Rain next 30 minutes disappear from the device when the radar nowcast is more than 15 minutes old, so flows that use them fail with “unknown tag”.
  • Time spans across midnight, such as 22:00–06:00, always fail.
  • A time span that has already passed gives an error instead of answering no.
So I built a new app where these work, and added what I was missing:
  • More weather models. Værvarsel uses one forecast, MET’s. A single model is sometimes spot on and sometimes far off. Værmeldingen combines five (MET Nordic, ECMWF, DWD ICON, UK Met Office and NOAA GFS), gives the most weight to the one that does best at each lead time and leaves out the biggest outlier. For the next two hours it uses MET’s radar nowcast, updated every five minutes.
  • Snow. I could not find a Homey app that tells how much new snow is coming or how deep the snow is. Værmeldingen does both, using seNorge’s snow model from NVE and MET (see Snow below).
  • Weather warnings. MET’s weather warnings are built in, so you don’t need a separate app for them.
  • Your own weather station. Use the readings from your own station, such as Netatmo, for the current weather, and let it adjust the temperature for the next few hours (see Your own weather station below).
  • Slippery roads and air quality. The risk of slippery roads, worked out from precipitation and temperature, and MET’s air quality forecast for where you live.
Værmeldingen supports all the flow cards from Værvarsel and MET Varsel, so you can switch without losing anything.
Sources
Source Used for
MET Nordic (MET Norway, the same data as Yr) Main forecast, most weight the first two days
ECMWF, DWD ICON, UK Met Office, NOAA GFS (via Open-Meteo) Weighted average; ECMWF takes over further ahead
MET Nowcast Radar precipitation, the next two hours (Nordic countries)
MetAlerts Weather warnings
seNorge (NVE and MET) Snow depth in Norway, every square kilometre
MET Sunrise Sun and moon
MET Textforecast The meteorologists’ own text forecast for your region
MET Air Quality Forecast Air quality in Norway, hour by hour
What you get
  • Now: weather type, temperature, feels like, wind, gusts, wind direction, humidity, pressure, cloud cover, fog, chance of thunder and UV.
  • Precipitation: now, the next 30 minutes, the next hour and the next 6 hours, the chance of precipitation and when it starts.
  • Snow: new snow for the next 6 and 24 hours, and snow depth (see below).
  • Temperature: lowest and highest in the next 6 hours.
  • Weather warnings from MET for your location, with level, type and duration.
  • Sun and moon: sunrise, sunset, sun hours today and tomorrow, and moon phase.
  • Slippery roads: the risk now and the highest risk in the next 6 hours (see below).
  • Air quality (Norway): MET’s air quality index and level (low, moderate, high, very high), PM2.5, PM10 and NO₂, now and hour by hour.
  • Model agreement: how alike the models are, so you can see how certain the forecast is. For the next 24 hours, the coming hours or a time span.
  • Text forecast for today, tomorrow and the day after, ready to be spoken or sent as a notification, and MET’s own text forecast for your region (Norway, in Norwegian).
  • Dashboard widget with now, the next hours and three days.
Snow
  • New snow is the averaged precipitation times the share the models expect to fall as snow (from the models’ snowfall and MET’s weather symbol, otherwise the temperature).
  • Cold snow gives more centimetres: 1 mm of precipitation gives about 0.8 cm of wet snow at 0 °C, 1 cm at −2 °C, 1.5 cm at −10 °C and 1.8 cm at −15 °C and colder.
  • Snow depth in Norway comes from seNorge, which models snowfall, melting and settling every three hours a few days ahead. If your location is in the sea on their map, the nearest land cell is used. Further ahead, and outside Norway, the change in the models’ snow depth is followed, so the depth also drops when it gets mild.
  • New snow is only the snow that falls; melting is not subtracted. Use the snow depth cards for the net result.
Slippery roads
A risk from 0 to 100, hour by hour. It is highest when rain falls at around 0 °C or lower (100), or on frozen ground after a cold spell (80), and when it freezes after recent precipitation (70). Wet snow and sleet give 60, colder snowfall 40 and frost on a damp night 30. The hours just before now count too, so rain that freezes overnight is caught. It is an estimate from the forecast, not a road report.
Do you have a weather station in Homey, such as Netatmo? Then its readings can be used for the current weather. You send them to Værmeldingen with a flow.
  • Which readings: temperature, humidity, pressure, wind, gusts and wind direction. Feels like and the 6-hour min/max are adjusted to match. Readings older than three hours are not used.
  • The next few hours: if your station is warmer or colder than the models, that difference is added to the temperature forecast. It counts fully now and fades out over six hours, so now and the next hours fit together.
  • The forecast further ahead still comes from the weather models.
  • See what is used: the device setting Own weather station under Status tells which readings come from your station, when the last one arrived and how much the temperature is adjusted.
How to set it up (Netatmo as an example):
  1. Create a new flow.
  2. When: your Netatmo outdoor module → The temperature changed.
  3. Then: Værmeldingen → Use reading from own weather station. Choose temperature (°C) as the measurement, and the Temperature tag from the Netatmo module as the value.
  4. Do the same for humidity, pressure and wind if you like: one flow per measurement, or several Then cards in a flow that runs every 10 minutes. Wind can be sent in m/s or km/h; pick the matching measurement in the card.
  5. To go back to the weather models only, use the card Stop using own weather station.
More than 100 flow cards. A few examples:
  • Precipitation starts within 15 minutes
  • The highest temperature tomorrow between 08:00 and 16:00 is below 0 °C
  • Total new snow tomorrow is above 10 cm
  • The snow depth is below 5 cm
  • A weather warning at orange level or higher is active
  • The highest risk of slippery roads in the next 6 hours is above 60 %
  • The air quality level is at least moderate
  • The weather changed
  • Get MET’s text forecast for tomorrow
Most values have three condition cards: now, the coming hours (highest, lowest, average or total) and a time span on a day (today, tomorrow or the day after). Time spans across midnight work, and a time span that has already passed answers no.
Getting started
  1. Install the app and add a device → Værmeldingen.
  2. It uses Homey’s location. To follow another place, such as your cabin, enter latitude and longitude in the device settings and add more devices.
  3. Optional: send readings from your own weather station with a flow (see above).
Device settings
  • Location: latitude and longitude. Leave empty to use Homey’s location.
  • Counts as rain from (mm/h): the limit for It started raining, It is raining now and when precipitation starts. Default 0.1.
  • Status: location in use, coverage, own weather station, sources in use, last updated and last errors.
Please post in this thread. It helps a lot if you include:
  • A screenshot of the device settings under Status.
  • Roughly where you are (town is enough) and what you expected to see.
  • For flow cards: a screenshot of the flow.
Suggestions are very welcome. I am quick to add new flow cards and values.
Requirements
All Homeys that run apps locally with Homey 12.4 or newer: Homey Pro, Homey Pro mini and Homey Self-Hosted Server. Homey Cloud is not supported.
Made for Norway. Outside Norway the forecast works, but weather warnings, snow depth from seNorge, air quality and MET’s text forecast are only available for Norway, and the radar nowcast only for the Nordic countries. The app tells you when you add the device, and Coverage under Status shows what is missing.
Data from MET Norway (CC BY 4.0), Open-Meteo.com (CC BY 4.0) and seNorge.no by NVE and MET (CC BY 4.0).
Changelog in the next post.
Changelog
The ten latest versions are listed here. Older versions are in the section below.
1.4.0
Your own weather station now also adjusts the temperature forecast for the next six hours, not just the current weather. New: the risk of slippery roads, now and the next 6 hours, with flow cards. New: air quality from MET Norway (index, level, PM2.5, PM10 and NO₂) with flow cards, Norway only. Model agreement now also has cards for the coming hours and a time span. Readings from your own station now count for three hours instead of two.
1.3.0
Your own weather station is now set with a flow: use the card Use reading from own weather station, for example when the temperature on your Netatmo changes. See Your own weather station in the first post. Choosing a station with Repair is removed, and the app no longer needs access to all of Homey. If you used Repair before, create the flow once, and your station is used again.
1.2.5
Made for Norway: when you add the device, the app tells you whether the location is in Norway. Outside Norway the device shows a notice, and the new Coverage line under Status tells you which features are missing there.
1.2.4
New app description: the complete weather app for Norway, with several weather models, snow, weather warnings and your own weather station.
1.2.3
The support link in the app now points to this topic.
1.2.2
New action card: get MET’s own text forecast for your region (Norway). Shorter app description following the Homey App Store guidelines, new device image, and clearer card titles for gusts and sunshine. Setup help and all updates are now in this topic.
1.2.1
Updated app description and search words, including snow and weather station.
1.2.0
Snow: new snow for the next 6 and 24 hours, with more centimetres per millimetre in cold weather, and snow depth from seNorge (NVE) in Norway. New flow cards for new snow and snow depth, and snow in the text forecast and widget.
1.1.5
Clearer own weather station: the device settings show which readings come from the station, or that it has no recent readings. Repair shows what the selected station measures.
1.1.4
Time-span cards for a period that has already passed now answer “no” instead of showing an error.
Older versions (1.0.0 – 1.1.3)
1.1.3
Many fixes: no false “warning ended” after network errors, sun hours today include the hours before the app started, the precipitation start time no longer drifts and shows “tomorrow” when relevant, time-span cards are correct on daylight saving days, and your own station now also adjusts the 6-hour min and max.
1.1.2
Fixed Repair on the device, which is used to choose your own weather station.
1.1.1
New app logo.
1.1.0
Use your own weather station, such as Netatmo, for the current weather: choose it with Repair on the device. New app icon and device icon.
1.0.4
The chance of precipitation now covers the next hour and follows the radar, and the current weather type follows the radar.
1.0.3
New devices are named Værmeldingen in Norwegian.
1.0.2
Updated device icon with sun, snow, rain and thunder around the map of Norway.
1.0.1
New device image with the map of Norway.
1.0.0
First version: weighted average of MET, ECMWF, ICON, UK Met Office and GFS, with radar nowcast, weather warnings, sun and moon, flow cards and a widget.
Updates – 29 October 2026
Test version: Værmeldingen | Homey → Install to get the latest version.
1.2.5
1.2.4
1.2.3
Updates – 2 November 2026
1.3.0
1.3.0 has been sent to Athom for certification. Until it is approved, the test version above is the way to install it.
Updates – 6 November 2026
1.4.0
1.4.0 has been sent to Athom for certification instead of 1.3.0, so everything comes in one release. Until it is approved, the test version above is the way to install it.
