Homey Actions for Logitech MX Keypad
Short description
Bring Homey to your fingertips: trigger Flows with a tap on your MX Keypad.
Overview
Trigger Homey Flows from the nine keys on your Logitech MX Creative Keypad. Each Trigger 1–9 action in Logi Options+ activates the matching Trigger 1–9 card in Homey.
Install Logitech MX Keypad from the Homey App Store
Requirements
- A Homey Pro with the Logitech MX Keypad app installed and running.
- A Logitech MX Creative Keypad and Logi Options+.
- The Homey plugin installed in Logi Options+.
- Homey Pro must be reachable from your computer over your local network. Homey Cloud is not supported.
Installation and setup
Follow these steps in order:
Install the Homey app.
Install Logitech MX Keypad on your Homey Pro and start the app. -
Copy your Homey connection details.
Open the Logitech MX Keypad app’s settings in Homey. Copy the Homey Pro endpoint and Integration key. -
Install the Logi plugin.
In Logi Options+, open Marketplace > MX Marketplace, search for Homey, and install it. -
Create the plugin configuration file.
On Windows, create the folder
%APPDATA%\LogiHomeyif it does not already exist. Then create%APPDATA%\LogiHomey\config.json. You can use PowerShell:New-Item -ItemType Directory -Force "$env:APPDATA\LogiHomey" notepad "$env:APPDATA\LogiHomey\config.json"
macOS: Create the file at ~/Library/Application Support/LogiHomey/config.json.
Add this JSON, replacing the example address and key with the values from your Homey app settings:
Important: The endpoint shown in Homey settings includes the API path, for example http://homey.local/api/app/com.homey.logitechmx/button-press. In baseUrl, use only the address before /api, such as http://homey.local. If homey.local does not resolve on your network, use your Homey Pro’s local IP address instead.
The plugin reads config.json each time a key is pressed, so saving the file is enough. Keep your integration key private. To use a different config-file location, set the LOGI_HOMEY_CONFIG environment variable.
Create a Flow and assign a keypad key.
In Homey, create a Flow and select Trigger 1 through Trigger 9 as its “When” card. In Logi Options+, assign the matching Trigger 1 through Trigger 9 action to a keypad key. For example, assigning Trigger 1 in Logi Options+ activates the Homey Trigger 1 card.
Local network and troubleshooting
This integration sends events directly from your computer to Homey Pro over your local network. It does not work with Homey Cloud. If a key press does not trigger a Flow, check that baseUrl is correct and that Homey Pro is reachable from your computer.
On Windows, the Logi Plugin Service log is located at:
%LOCALAPPDATA%\Logi\LogiPluginService\Logs\plugin_logs\LogiHomeyActions.log
