[APP][Pro] Ecovacs Deebot - You relax. DEEBOT delivers
large
This is a new Ecovacs Deebot app. It’s the successor to the Ecovacs app built by Le_Cactus.
It’s a rebuild using the latest ecovacs-deebot API module.
Most of the functionality was no longer working on newer models (T80, X9, and newer) because Ecovacs changed some details of the API. That’s why I started by trying to unify the main functionality (start, stop, pause) and the main settings (speed, water usage). Using different capabilities and flows eventually resulted in a new app version.
You can install this app alongside the old version. This allows you to test the new app and migrate your flows if you decide to switch.
About API and devices...
  • Based on the JS module, really old XML-based devices are not supported anymore.
  • Older devices are using a different API for some commands and data reading. So if your device doesn’t support all functionality, please report it providing details about the device and the functions.
reserved
Still the same..:smiling_face_with_tear:
75966b76-96e5-4899-afdb-68b8de114caf
Yeah, the bas library and auth is the same for both apps.
thanks for this new app.
I am experiencing some bugs with my X8
hope this helps !
Thanks, it’s fixed for next version :+1:
Abou park position: This is a function from the last app. You have to save a position first in device details. Let your Deebot go to a target position (move via Ecovacs app), the save position. Then you can use this card to to let your Deebot go to this position.
