Komfovent C6M is an independent Community app for local control and monitoring of compatible Komfovent DOMEKT ventilation units from Homey Pro.
Update, 4 November 2026: v1.9.1 is available in Test (Build 19) and has been submitted for review. It adds active-target WHEN cards, on/off control and native holiday scheduling with an early-end card. The duplicate fan-slider page has been removed; saved profiles and all three Dashboard sizes are kept. Existing devices upgrade without re-pairing. Physical checks and the remaining beta tests are explained in the release update. This is not a Live release.
Install the Test version: Komfovent C6M | Homey
What is included
- One-tap modes: Away, Normal, Intensive and Boost
- Linked and separate targets for all four saved standard profiles: percentage control, plus experimental opt-in CAV control in confirmed m³/h or l/s
- Profile-specific electric reheating permission, separate from actual heater output
- Live fan levels, temperatures, filter life, alarms and unit status
- Panel 1/2 temperatures, display-panel selection and the active profile temperature target
- Flow action for saved standard-profile temperature targets, 5–40 °C in 0.1 °C steps
- WHEN cards for changes to active airflow and temperature targets
- Optional on/off Flow action
- Native holiday dates and an early-end Flow action, with a separate beta setting
- Native Homey Energy support with live power in W and total consumption in kWh
- Automatic Insights history and standard Energy Flow triggers
- Three Homey Dashboard sizes: Mini, Compact and Advanced; Mini includes a reheating-permission switch
- Flow actions and conditions for automation from other smart-home devices
- Fully local Modbus TCP communication; no vendor cloud account or analytics
Compatibility
The main local test unit is DOMEKT R700 with C6M firmware 1.4.47.74. Pairing performs a read-only compatibility check before adding the device. A Homey Pro and a correctly configured C6/C6M controller with Modbus TCP enabled and a reserved local IP address are required.
Earlier beta feedback also covers W1 handling and profile control on an R400 H, and CAV monitoring on an R450. Those reports are not a full qualification of every model or firmware. Validated CAV configurations can now be paired, but CAV control is a separate opt-in beta setting. Please check the physical response on your unit and report your model, firmware and units. VAV/DCV and unknown configurations are not supported for control.
R700 checks cover panel 1, active-target Flow triggers, on/off, Holiday microventilation, early cancellation and return at the unit’s day change. Tester feedback also confirms both panel-temperature display options. Other temperature profiles/control methods, physical CAV writes and multi-day Holiday cycles still need confirmation. The original R450 disconnection report has not been root-caused. Sensor availability depends on the unit and its connected hardware.
Control scope
Standard control covers the four documented modes, complete supply/extract pairs for their saved profiles, profile-specific reheating permission and the four standard profiles’ temperature targets. Optional on/off uses the unit’s own command; it is not a mains isolator. Holiday writes only its native date pair, not a special-mode command. On/off, temperature and Holiday control have separate settings, off by default. Changes use exact readback verification. Temperature targets do not change the control sensor or force heating on.
Holiday follows the unit’s own clock and existing microventilation/heating settings. Check the dates and physical response on your unit; stop built-in room demand control before scheduling it. It remains beta on other firmware and CAV configurations. Actual fan readings, monitoring, pairing and energy data are read-only. Kitchen, Fireplace and Override remain status-only. W1 stays visible as a maintenance reminder; other faults and unknown alarms still block control. Saved profile edits are persistent, not a live fan dimmer, and have no automatic return. Unequal targets do not establish pressure or provide fireplace safety. Optional room-sensor demand control still requires percentage configuration.
Feedback wanted
Please report:
- Ventilation model and controller firmware
- Whether pairing succeeds
- Whether mode/profile changes work on the first tap, including linked targets and CAV units where applicable
- Whether live W and cumulative kWh appear in Homey Energy and Insights
- Panel 1/2 readings, active temperature target and the temperature Flow card, including the chosen panel and control method
- Holiday start, microventilation and end behaviour, including the controller clock and firmware
- Any error text (please remove local IP addresses before posting logs)
This app is not affiliated with or endorsed by Komfovent. The app itself is free; this topic is the initial support and beta-feedback channel.
Thanks for testing!
Trond Ole Namlos
