This is the public support and bug-reporting topic for Envisalink for DSC, a community-developed Homey Pro app by Lexi and Michael. The app connects Homey directly to a DSC PowerSeries alarm panel through an EyezOn Envisalink on the local network—Home Assistant is not required.
Install the Test release
Install Envisalink for DSC from the Homey Test channel
Version 1.2.0 is now available for beta testing. It has not yet been certified by Homey, so please begin with monitoring and verify that partition and zone updates are reliable before enabling arm or disarm control. Test releases can be installed on Homey Pro running Homey 13 or newer.
Feedback from Envisalink 3, Envisalink 4, and compatible DSC PowerSeries users is welcome. Please tell us what hardware and firmware you tested, even when everything works correctly.
Reporting a bug
Please reply to this topic with:
- A short description of what happened and what you expected instead
- Steps that reproduce the problem
- Homey Pro model and Homey software version
- Envisalink model and firmware version
- DSC panel model
- Envisalink for DSC app version
- Whether the problem occurs every time or only sometimes
Creating a Homey diagnostic report
Reproduce the issue, then create the report as soon as possible—preferably within five minutes:
- In the Homey mobile app, go to More (…) → Apps → Envisalink for DSC → Settings (
). - Tap Create diagnostic report.
- Enter a short note describing what you attempted and the approximate time.
- Email the generated report ID to lexitheoverseer@gmail.com. In the forum, simply say that a diagnostic report was sent.
A report ID looks like c406412f-95c1-46f8-bc55-0bbdcceec20e. Please send the ID privately by email rather than posting it in this public topic.
Never include your Envisalink password, DSC alarm user code, public or local IP address, MAC address, serial number, or other security credentials in a diagnostic note, email, forum post, or screenshot. Screenshots should be checked carefully before posting.
For private support, email lexitheoverseer@gmail.com.
Initial compatibility
The first physically tested system is an Envisalink 3 running firmware 2.05 with a DSC PC1832. Envisalink 4 and other compatible DSC PowerSeries panels use the same local protocol but will be confirmed through beta testing.
Safety
This app supplements but never replaces the DSC panel, keypad, siren, professional monitoring, or life-safety equipment. Do not use software testing to trigger fire, panic, or emergency signals. If the alarm is professionally monitored, place the account on test with the monitoring company before intentional alarm testing.
Envisalink, EyezOn, and DSC are trademarks of their respective owners. This is an independent community integration and is not affiliated with or endorsed by those companies.
