[APP][PRO] Mode Switch
Mode Switch for Homey
Want your home to react intelligently without having to build separate flows everywhere?
With this app, you configure your rules once — after that, everything works automatically.
:backhand_index_pointing_right: View and test the app: Mode Switch | Homey
What makes this app different?
You no longer need extensive flows for basic automations.
For example:
  • Motion detected → light automatically turns on
  • No motion → light automatically turns off again
  • Everything configurable per zone
  • Works instantly, without complex Flow logic
Mode-based automation
Your home automatically adapts to your situation:
  • Home / Away / Sleeping / Vacation
Can be changed manually
Or fully automated:
Automatic examples:
  • Everyone leaves → Away mode
  • Nobody home for X hours → Vacation mode
  • Everyone asleep → Sleeping mode
  • Someone wakes up or comes home → Home mode
No separate flows needed — everything is managed centrally in the settings.
Smart lighting without the hassle
  • Configure lights per zone
  • Automatically turn on with motion
  • Automatically turn off when no motion is detected
  • Adjustable dim levels
Temperature rules
  • Automations based on temperature
  • For example: control heating or cooling per mode
  • Smart combinations with presence and time schedules
Device monitoring (without complicated flows)
Monitor devices such as:
  • Washing machine
  • Dryer
  • Dishwasher
As soon as a device starts or finishes:
  • Instant triggers available
  • Notifications possible
  • Ready to use in Flows
Scheduling & smart time schedules
Let your home automatically react based on time:
  • Turn lights on at a specific time
  • Only active within a specific mode
  • Automatically turn off again after X time
  • Random times possible
  • Work with time windows
  • Support for sunrise and sunset
Screenshots
Modes — Configure which devices turn on or off when the mode changes to Home, Away, Sleeping, or Vacation
Zones & Sensors — Configure rules such as: pantry door open → light on, door closed → light off. Or motion in the hallway → hallway light on. No motion for 20 seconds → light off.
Temperature Rules — Set temperatures per mode, for example: Vacation mode → temperature set to 17 degrees.
Monitoring — Monitor appliances. For example, when a dishwasher starts, a trigger is sent which can be used in a Flow card for notifications. Or when it finishes, another Flow card can announce that the dishwasher is done.
Scheduling — Configure lights on schedules or after sunset, and automatically turn them off again after a set number of hours.
Automatic Mode Switching — Automatically switch all modes. For example, when everyone is away, the mode automatically changes to Away.
Widgets:
Enjoying the app and want to support development? :raising_hands:
:backhand_index_pointing_right: Please support me via PayPal.
All support is greatly appreciated!
Mode Switch
Perhaps it would be good to add the link to this topic in the Homey App Store, @Erikje.
Didn’t fint this topic earlier.
Very interesting app, thx!
Thanks for your advice, I will definitely add it. Nice to hear that you like it, greatly appreciated.
I just put V2.7.0 into testing.
Made some adjustments for the Homey App Store so it can also get approved.
I also made an update for the “Mode” widget, so you can display a device with temperature measurement. You can now also enable the weather image as the background and choose how visible you want it to be:
And with the “Monitoring” widget, you can now see how many kWh the device has used and how long it has been running:
Also created tokens so they can be used in flows as well :slightly_smiling_face:
V2.7.1 has now been moved to testing due to an error on the settings page. This issue has been fixed, and new weather background images have also been added.
Hi
When I select “invert” in advanced flow on AND card “Current mode is..”, it does not change text from “is” to “is not”, making it difficult to know what is configured. Mode Switch version 2.7.1. Thanks.
Is it possible to have the option to make “Active mode” as default in the Homey Pro app on the mode switch device instead of “Sub mode”. Thanks. Great and awaited app!
Hi Sanu,
Thank you so much for wanting to use my app. I did notice that I forgot to include that, so I’ll definitely update the text when the card is flipped. I’ll also take a look at whether I can make it a configurable setting.
It’s truly great to hear you say that this is an app you’ve been waiting for. Feedback like that really means a lot and motivates me to keep improving it! :blush:
Thank you for the great app, it’s appreciated!
Could you also add something around water management? For example, support for indicating whether a shower or bath is currently in use, or options related to managing an irrigation/sprinkler system.
Hi TammeMagal,
Thank you so much for your donation, I truly appreciate it.
That’s actually a great idea to see if I can add support for that as well. It would probably need to be able to detect something like a water meter or a boiler/heating system that indicates when there is a heat demand.
I’m just not sure yet how I could reliably detect an irrigation/sprinkler system, mainly because I don’t have one myself to test with or base the implementation on.
But I’ll definitely give it some thought and see what the best way would be to add this.
Hi Sanu,
I have now deployed version 2.7.2 for testing. With this version, you can select the default list for the Device Mode Controller in the device settings. After making the change, please restart the app for it to take effect.
Hi TammeMagal,
I’m also still working in the background on adding a kind of activity system, such as Showering and Irrigation. Unfortunately, my current implementation keeps crashing all the time.
Just so you know, I haven’t given up on it — I’m still actively working on it because I think it’s a fantastic idea and would be a great addition to the app.
I’ve just put version 2.8.1 into testing. With the help of AI, I’ve added support for French, German, and Spanish.
Is there anyone in this group who speaks one of these languages and would be willing to test it? I’d really appreciate it if you could check whether everything works correctly and whether the translations make sense and are accurate. Thanks in advance! :blush:
It works :slight_smile: I got version 2.8.1 and it works fine. I donated as thanks.
Thank you so much for the donation! I’m glad the option is working. Enjoy using the app! :blush:
Could you take a look at version 2.9.0? It’s currently available in the test environment.
In this version, I’ve tried adding activities that can be activated using multiple conditions. I hope this is roughly what you had in mind. I still need to work on it further, so it’s not fully complete yet.
I’d really like to know whether this is more or less what you meant, and if you have any suggestions or feedback on how it could be improved.
Could you also let me know if it crashes for you? It still crashes for me sometimes, but that might also be because my Homey’s memory is already quite full.
Hi
Have you considered creating an new Homey Pro app that only features a multi-mode virtual device where you can customize the modes, and that you can have more than one such virtual device on your homey pro? This is my needs really, because I do not want to spent time on other apps such as the Device Capabilities which is just overkill in this case and less user friendly.
Hi Sanu,
Thanks for the suggestion! To be honest, that was never my original intention for this app.
My goal was to create an app that manages the house mode and automates as much as possible, so you don’t have to create lots of flows. That’s also why I added things like appliance monitoring, where the app can already detect when an appliance starts or finishes, and you only need a single flow to receive notifications.
That said, your idea is definitely interesting. In theory, I could either create a separate app based on your idea, or add a new virtual device to the current app that can be added multiple times, with fully customizable modes.
One question though: would you also want those custom modes to switch automatically, similar to how the current Mode Switch app works? Or would you mainly use them as virtual mode devices that you control manually or through flows?
Hi
Yeah I know Mode Switch is a different and bigger concept, I only require a multi-mode virtual device :slight_smile:
I have multi-mode devices for example for my alarm system, using modes such as away, home and sleeping. I am using your mode controller device for heating where I use similar modes. I would also like something similar for my roller shutters, indicating if they are all Up, Down or custom position.
I usually end up using flows since I rather have a bit of granular control, although the down side is more complex flows that take time to create. I would also favor multi-mode devices that could have the states “manual” (used as override) and “automatic”, controlling heating, roller shutters and lights. I use this as override when I have non-tech people in my house or there is a need to stop the automation to keep things simple because there is too much going on that does not fit automation, such as someone doing work in my home, or a friend/loved ones staying. Currently I just use virtual devices where ON is automatic operations, and OFF is manual mode (override).
I also use virtual devices on dashboards such as SharpTools to display or control, then it is important to reduce the number of tiles (devices) on the dashboard due to limited space on the dashboard (tablet).
I am more than happy to donate for such app to be made, not that it will ever be enough for the work needed, but at least I can offer some appreciation through donation.
If I can recommend, having a separate app with just the multi-mode virtual device would be a good start, and multiple of those virtual devices, then you can see how it works out. Not sure what others out there needs.
I can look into it, because I do think it’s an interesting idea.
My only concern is that it might overlap with the Device Capabilities app. I actually use that app myself and really enjoy it, so I’d rather not step into the same territory or unintentionally compete with another developer.
Maybe it’s worth asking the Device Capabilities developer what he thinks. He might already have something similar planned, or perhaps he sees it as a different use case altogether.
If he doesn’t see an issue with it, I’d be happy to explore building a simple app focused purely on customizable multi-mode virtual devices. I just want to make sure I’m adding something useful to the Homey appstore rather than duplicating someone else’s work. @Arie_J_Godschalk can you look at the idea of Sanu?
