Native Homey support to connect locally to Lutron RA3 devices.
In test currently - Lutron RA3 | Homey
@alistair the app did not pick up the accurate state of my devices after first connecting to the Lutron bridge. For example, my guest bedroom shows all the devices as on in the device tile. All those devices are actually off. Image attached.
Once I toggle it it in either Homey or the Lutron App, the device tile shows the right state.
FEATURE REQUEST - Add shades as supported devices.
@fxl90 huh - I’ve been using this a fair bit in my own home and haven’t run into this. I wonder if it’s a “first run” issue. Next time you restart Homey, can you see if the status is correctly reflected?
Either way - I’ll see if I can track down the bug, but more data helps ![]()
Sent diagnostics report b2a73a15-a075-4963-8eb1-1ec293ae85b1
