[APP][Pro] TP-Link Omada
This is a Homey app for the TP-Link Omada controllers (OC200, OC300, OC400 or self hosted).
Cloud controllers are not yet supported, if you have a cloud controller and are interested in this Homey app, please let me know so I can add support for it.
Version 1.0.
  • Fix app manifest
Version 1.0.2
  • Added telemetry
Version 1.0.3
  • Added signal strength
Version 1.0.4
  • Fix signal strength
Version 1.0.5
  • Fixed signal strength
Version 1.0.6
  • Added reconnect button
Version 1.0.7
  • Added reconnect Flowcard
Version 1.0.8
  • Added Block button
Version 1.0.9 [LIVE]
  • Fixed translations
Thanks for creating this app! I just installed the app and noticed some things. Fist when adding a new device it says the IP-address, e-mail address and password. I think the e-mail address should be a username, since Omada doesn’t specifically require a e-mail address to log in. Also when you click on the save button when adding a client it shows pair.saving next to the busy icon. Lastly, it doesn’t add the device when I want to add it. It keeps saying its busy but doesn’t continue adding the device. Hereby my diagnostic report: 1faf6dd1-75a5-4afd-89c2-b7094688a7de
It is usually your TP-Link ID email address. So the email address of the TP-Link ID that you bound your controller with during setup. So you need to enter your TP-Link ID email and password.
That should be fixed in 1.0.9
I see it returns a 404 not found, what is your Omada controller port? For me it’s 8043, but maybe it’s different depending on the setup. I can add a port selector if necessary.
In my case my e-mailaddres doesn’t equal my username. So it can be the same, but it’s not always the case :).
This is fixed :)!
I also use port 8043. I Tried to connect a different client that I also added to Homey via an IP-adders (my car charger) but it has the same problem unfortunately.
That should still work, just enter your username in the email address field
What controller do you use? Also, you should enter your Omada controller IP, not your client IP. The clients get discovered automatically from the controller
