[App][Pro] Kaisai Modbus
Monitor and control your Kaisai Air-to-Water Heat Pump directly from Homey — no cloud, no delays. This app communicates locally over Modbus TCP through an RS485-to-TCP gateway, giving you fast, reliable access to your heat pump’s data and controls.
What you can do:
  • Switch heating/cooling on or off and set operation mode (Heat, Cool, Auto)
  • Adjust water target temperature and DHW (hot water) target temperature
  • Monitor live temperatures: water outlet, water inlet, outdoor, room, DHW tank, and backup heater
  • Track energy usage: electrical power consumption, thermal output, and real-time COP
  • Monitor water flow rate
  • View system status: compressor, water pump, defrost cycle, and outdoor unit activity
  • Control DHW heating and silent mode
  • Get notified on errors with automatic alarm detection and error codes
  • Build automations with flow triggers, conditions, and actions for all key parameters
Requirements:
  • Kaisai Air-to-Water Heat Pump (AWHP) with Modbus RTU support
  • RS485-to-TCP serial gateway (like Elfin EW-11 or compatible) connected to the heat pump’s H1/H2 Modbus port
  • Homey Pro with local network access to the gateway
TEST Version
Kaisai Modbus AWHP | Homey
RELEASE Version
pending approval
