[NEW][APP][PRO] OpenWRT Router - Presence Detection and network management
Test version: OpenWRT | Homey
I have been using my Netgear R7800 router for many years, using the Netgear app to get accurate presence detection for family members and guests. But Netgear stopped publishing firmware updates for this router, and I wanted to do fancy stuff with VLANS for Guests and IOT devices. So I switched to using OpenWRT firmware. The advantages are great:
  • I can safely use my ‘old’ routers and AP’s for many more years because of the continuous firmware and security updates
  • I can implement VLANs to seperate guests and IOT devices from the rest of my network
  • I can make use of many advanced features and plugins
But the downside is: When you want to do fancy stuff like vlans, there is a steep learning curve to concur.
I have a setup with a main router to my ISP. This is doing DHCP (handing out IP addresses) and doing the firewall stuff. Then I have another 2 routers that I have configured as WiFi Access Points / managed switches. This allows me to have great wifi coverage throughout the house and the garden, with seamless fast roaming when I walk around :slight_smile:
Presence Detection, Network control, Energy Monitoring
  • Presence detection based on smartphone WiFi or ethernet connection
  • Monitor and control your wifi network(s) and its connected devices
  • Block the WiFi of your kids after dinner
  • Monitor the energy usage of your network devices, e.g. the T.V.
See and log:
  • internet connection status
  • the internet upload and download speed
  • connection status of attached devices
  • WiFi quality and bandwidth per device
  • Energy use per device
Act on:
  • device coming online or going offline (presence)
  • device bandwidth or wifi link change
  • detection of an unknown device connecting to the network
  • alarm when internet connection goes down
  • change of internet up/download speed
Do:
  • send WakeOnLan (WOL) to a MAC address
  • block and allow an attached device by MAC address
  • enable and disable Guest Wifi
  • reboot the router
Router device setup in Homey
The app is intended for OpenWRT routers that work in Router mode. You can add OpenWRT routers that are configured in Access Point (AP) mode for better/faster detection of wifi devices throughout your house.Your Homey should be connected inside the LAN part of the router, not from outside (WAN). On app startup, Homey will try to automatically enable traffic statistics (up/download speed) by installing the nlbwmon package.
Presence detection
After adding your router to Homey, you can start adding the mobile or fixed devices that you want to track for presence.
Energy monitoring
After adding your router to Homey, you can add additional devices that you want to monitor for power, e.g. your T.V. or printer. In advanced device settings enter the estimated / average power usage of the device when it is OFF or ON. Now when you turn on your T.V. you will see that the estimated power is included in Homey Energy tab.
Supported routers
This app has been developed and tested on a Netgear R7800 router running OpenWRT 24.10. It should be compatible with all OpenWRT routers running firmware 24.10 or higher. To check if your router can work with OpenWRT firmware, check this table.
DONATE
If you find this app useful do not hesitate to donate
:face_blowing_a_kiss:
New version 1.1.0 is ready for testing: https://homey.app/a/com.gruijter.openwrt/test/
  • Added Router Reboot flow card.
  • Fixed ul/dl speed monitoring.
  • Improved phone presence detection.
  • Improved translations.
New version 1.2.0 is ready for testing: https://homey.app/a/com.gruijter.openwrt/test/
  • Added WOL flow card
  • Added SSID on/off flow card
  • Added wifi radio on/off flow card
  • Added block/allow device flow card
  • Added deviceIsOnline flow card
  • Fixed etherwake installed check
  • Updated readme
  • Code fixes and improvements
Do any of you users already have feedback for me? I know you are using the app :wink:
New version 1.2.1 ready for testing: OpenWRT | Homey
  • Reduced router CPU load
Still waiting on first feedback from users :wink:
Thanks for the great app!
I tried connecting it to my Teltonika RUT241 (OpenWRT based). The app detected my router and I was able to add it! I am however missing the WAN upload etc, but I guess this is due to the router running in passthrough mode to my Unifi UDM Pro SE. I was also able to add my UDM as a device :+1: Also do you think it would be possible to add WAN data usage? Since the RUT241 is a 4G router :slight_smile:
Only on openWRT routers the data usage is supported.
