[LIST] All known Tuya-based apps
This list contains all known Tuya-based apps. If you know any more, please mention them below.
EDIT Since I’ve reached the limit of the forum posts, I’ve moved my list to GitHub
Note: None of these devices have been confirmed to work with Homey, they have been discovered using this strategy. This information might not be accurate. If you notice any apps that aren’t Tuya-based on this list, please let me know.
Suggestion, sort on alphabet
Done!
Seems like I’ve reached the character limit
We’ll continue on GitHub:
I’ve spent the last few days discovering and adding more Tuya-based apps. There are currently 695 apps in the list. If you use/know any that aren’t on this list, please let me know!
EKF Connect 2023
There is also EKF Connect Home, but that’s not a standard Tuya OEM app, it’s a custom app based on Tuya API:
I know because I was the product manager for these apps at EKF
Thanks, I’ve added the EKF Connect 2023 app. I’ve checked the EKF Connect Home app APK and it appears to use multiple systems (Tuya for smart devices and some P2P system for cameras). This is similar to the Osaio app, which uses Tuya for the smartplugs and their own system for the cameras. I won’t add those apps, since those are only partially Tuya-based.
