[App][Pro] Trakt - Lights out, it's movie time!
Elevate your home entertainment experience with the Trakt.tv app for Homey Pro. Seamlessly connect your Trakt.tv account to Homey and let your smart home respond to what you’re watching.
Example Automations:
  • Movie Night Mode: When you press play, Homey dims the lights and lowers the blinds.
  • Wrap-Up Routine: Finish watching, and Homey restores your default home settings.
Great app! Thank you for that.
One question: can you map the movie as tag/variable? I would like to change the light and mention the name of the movie on a timeline entry.
I’ve already included a bunch of tags to the starting flow card.
But I could maybe also add them as global variables, so they can be used at any point.
Nice ! I search again for it - couldn’t find it on my first try.
Pushed a new build to test!
version 1.0.2
  • Added multiple device capabilities so the information of what is being watched is globally available as tags for your flows.
Hi, how do i connect my trakt account on my Homey? I already installed the Trakt app on my homey but i didnt see any option to log/in or seomething. When i make i new advanced flow Trakt is also not available in the litst with apps to choose out as a starter.
You have to add a device “Trakt” and there you can connect your account :slight_smile:
It seems to fail, when I try to log into trakt? Any advice? I believe its pointing to the wrong api for logging in or has been updated since the last release.
I’ll have a look this weekend, can’t remember to have gotten an email from Trakt that their authorisation endpoint has changed. Normally I would get an email on breaking changes.
Thanks again for reporting this issue.
I’ve just pushed a new version of the app, turns out trakt did change their authorization endpoint (or at least stopped supporting it under the api.trakt.tv subdomain)
Thank you for such a quick turn around. I’m all logged in.
