Write to Timeline from Homey Script
How can I write to the timeline from within a script?
I have the same question. Have you found a resolution?
I found this, which worked for me.
await Homey.flow.runFlowCardAction({
uri: ‘homey:manager:notifications’,
args: {
text: ‘some text ’ + someVariable + ’ some more text’
This worked for me:
uri: “homey:manager:notifications”,
args: {
text: “some text” },
dont use quotes (’ ') but (" ")
To make it work for me (too debug), I neede it to change to:
uri: ‘homey:flowcardaction:homey:manager:notifications:create_notification’,
args: {text: 'Step 2a '},
For some reason, needed to change url to be with " and not with ’ - then works as a charm
// My timeline test
result = await Homey.flow.runFlowCardAction({
uri: “homey:flowcardaction:homey:manager:notifications:create_notification”,
args: {text: ‘HomeyScript write test’},
console.log(result)
return
This is because (all) the posted code parts in this topic aren’t formatted as code, like this: first and last line start with 3 backticks:
Your code here
Fancy quotes and fancy double quotes are invalid.
Code formatted as code should look like this:
    uri: 'homey:flowcardaction:homey:manager:notifications:create_notification',
    args: {text: 'Step 2a'},
(Note the ‘copy’ icon at the top-right, for easy and error-free copying)
hmm. I don’t know why, but it does not work for me(
Fancy quotes?
I needed the same functionality. After checking the available actions in Homey.flow.getFlowCardActions() I found this solution that worked for me on my Homey Pro 2023.
  uri: 'homey:manager:notifications',
  args: {
    text: 'Hello from HomeyScript'
