Wiser UK Thermostat support
Hello
I am trying to connect my wiser thermostat to homey (this product: https://wiser.draytoncontrols.co.uk/product-selector/46)
Any help will be welcomed.
There is an app for it but I don’t think there are same company.
Thanks
Hi @tembelreis ,
why do you think they are different companies?
Drayton by Schneider Electric and the Wiser App (Subtitle Schneider Electric) could be rather the same company or group.
Just if you buy the set, you will get a channel heat hub that you probably don’t need or even cannot use, if you use the other (zigbee) parts in your homey. And the Danfoss thermostats you might rather connect with the Danfoss App.
Probably you might try the Best Buy Guide and look for radiator valves and thermostats.
Thanks Dirk
But i am now even more confused :blush:
So ok they are the same company but none of the thermostat products I have from them (I am in the UK) are appearing in the wiser homey app. So I think they may be under the same umbrella company but perhaps UK one is a different entetiy.
My ultimate goal is to connect my existing wise heating bridge and thermostats to my homey.
Thanks again for your help.
See thread here.
Hi, I tried last November and Drayton gave this reply
“Thank you for providing the source of the information.
The link you provided is for a different system controlled via another app rather than the Wiser Home system and app, and as such is not directly applicable in this instance. The product you have provided a link to is controlled via the ‘Wiser by SE’ app rather than ‘Wiser Home’.
The ‘Wiser by SE’ system is for German and European markets which differ to the UK version of the system, hopefully this has been able to have answered your query.”
So essentially, no there is no support from the manufacturer for UK Wiser products in Homey.
What did you do in the end?… home assistant?
As I only have a couple of things on Homey at the moment (as I have found multiple products with no apps), nothing. Shame, nice hardware, shame I am not using it to it’s potential. I came from Home Assistant as I am not a programmer and I am hoping more apps are generated.
Yeh I’ve been thinking about homey too as I do like the app however missing the Drayton wiser stuff is a deal breaker, I’m not a programmer either so wouldn’t know where to start, shame.
To be honest, I never knew Schneider had a completely separate brand for the UK market. I’ll reach out to my contacts at Schneider to see if they can connect me with their UK colleagues so we can add support for Wiser by Drayton.
We have a good working relationship, so I don’t anticipate any issues. I’ll keep you all posted!
Thanks. If you are looking for other partners/ companies to do apps for, in the UK I could suggest Octopus Energy (though someone in the community is looking at this), Givenergy and Hypervolt.
An official integration for Octopus Energy is already in the works! Got in touch with them some time ago :wink:
@Doekse if Wiser UK support was added it would definitely allow me to switch to Homey Pro, without it the eco system wouldn’t fit my use case.
This would be great. It is the only part of my smart home I can’t currently integrate into Homey. Any help would be appreciated.
Same here. I am buying a house with the Wiser UK system in it, and came here to check if it was supported before I bought. Shame its not.
adding a request for this!
At the moment I am using the home assistant integration to pull in the Wiser to Homey
Add another future user to that list
Any more on this?
Also any possibility on the UK battery/ inverter company GivEnergy having an integration? They work well with Octopus and have a HASS integration
Thanks
I know I’m a bit late here, I’m in the process of moving from Home Assistant over to Homey and bumped into the lack of Drayton Wiser integration. I’ve hacked the below together over the weekend to try and get something going. It’s pretty basic and may be likely to break, but at the moment supports reading/setting room temps, grabs humidity from room thermostats, and reports battery levels/alerts. I’m hoping to add in the ‘Boost’ setting sometime (because my wife needs it in the winter!).
To any mods - apologies if I’m not allowed to post this here. Please feel free to remove it if I’ve broken any rules.
Please feel free to install & test - you’ll need the IP address of your hub (although the app may be able to find it on your network) and the secret key, which is a terrible faff to get and involved me sitting in the loft in the dark for half an hour.
Thanks
Edit 2026-05-15: Changed domain before my submission went through approval, so updated the link above.
Tried the app on Homey Self Hosted but it was crashing.
Could not mount /dev/random : 32
