[Unsupported] Homey v2 REST API
I have no idea how to authenticate local, Using the homey.ink procedure i was able to authenticate on cloud and use all the API’s. As i had trouble finding the needed info here, here is my contribution. Hope this is helpful to someone.
Getting a unlimited key
First step is to get a token that is reusable (longer then 24 Hours), because the API bearer token is only usable for 24 hours and we don’t want to change our code every 24 hours. homey.ink is our solution as it generates a key without an expiration date.
Here we go:
Step 1: Go to https://homey.ink using google chrome.
Step 2: Right click on the page and select inspect(inspecteren) or use Ctrl + Shift + I
Step 3: Select the Network Tab (this will show the network traffic after the authentication is done)
Step 4: Use the “Log In” button and follow the authentication steps.
Step 5: Use the scrollbar if needed, (If you followed this step by step you’ll probably only see one item)
Step 6: select the item named “token, api.athom.com/oauth2”
Step 7: In the headers view scroll down to Form Data, and select the “view source” button.
Step 8: below the “View Source” button the needed key will be shown. Copy it . We’ll need it for the API authentication. it will look something like this:
client_id=09ab2b247cdff0918abfd00d&client_secret=l159fjann0173h2jllsppehg2vj4l28dhhakl3010&grant_type=authorization_code&code=09ab2b247cdff0918abfd00d47cdff0918a2b2414
P.S. This is just an example. your key will look a bit different.
now send the following
POST https://api.athom.com/oauth2/token
Headers:
Content-Type: application/x-www-form-urlencoded
Body
The response will include a refresh token.
To build the “unlimited” key, use the first part of the key, like:
  • client_id=09ab2b247cdff0918abfd00d&client_secret=l159fjann0173h2jllsppehg2vj4l28dhhakl3010&grant_type=
  • Add: refresh_token&refresh_token=
  • and then add the refresh_token (gotten from the authentication above)
The result will look like this:
client_id=09ab2b247cdff0918abfd00d&client_secret=l159fjann0173h2jllsppehg2vj4l28dhhakl3010&grant_type=refresh_token&refresh_token=09ab2b247cdff0918abfd00d47cdff0918a2b2414
This key can be reused in your code to re authenticate yourself every 24 hours without the need to open your brouwer and the former steps.
Getting the bearer token
With the key we got above we can now programmatically get a bearer token.
There are a couple of steps needed to get it, the bearer token is valid for 24 Hours. after 24 Hours you will need to get a new bearer token.
Step 1:
use the KEY you’ve got from Getting a unlimited key as body.
Headers:
Body
KEY
Result: will be a Json formatted output. we’ll need the “access_token” value.
Optional Step:
With this request you can get all kind of interesting data, i.e. cloud ID’s and users.
Use the ACCESS_TOKEN gotten in step 1.
GET https://api.athom.com/user/me
Headers:
Authorization: ACCESS_TOKEN
Step 2:
POST https://api.athom.com/delegation/token?audience=homey
Headers:
Result: A JWT formated token.
Step 3:
Use the JWT_TOKEN gotten in step 2.
Use the CLOUD_ID for your homey, this can also be found in the Optional Step.
POST https://CLOUD_ID.connect.athom.com/api/manager/users/login
Headers:
Content-Type: application/json
Body:
{“token”:“JWT_TOKEN”}
Result: the bearer token that can be used in all API’s
API Test Step
Use the BEARER-TOKEN gotten in step 3
GET https://CLOUD_ID.connect.athom.com/api/manager/devices/device/.
Headers:
Authorization: BEARER-TOKEN
