At the moment it only possible to control the apple tv when you pair it as remote. in my smarthome i use node-apple-tv to control my ATV 3 and 4K HDR because my Homey has no visibility to use IR commands in flow {like : menu x times to get back to main -> then navigate the selection to settings ( i moved them on the top right corner) -> select -> xy down to shutdown -> select } 2-3 sec later appletv 4k was schutdown. that i had used before i changed to node-apple-tv maybe this could be used for a homey app if someone can do this.
