Congratulations with the 10 years!
My issue over all the years: when you address multiple Hue lamps at the same time in the advanced flows. You see that some lamps don’t follow the commands.
When will you solve this problem? Now I have to add delays in the flows to solve it.
I think it should be solved by the software itself. Since you get feedback from the lamps what the status is. You should check in the background if the send command is actually executed or not and correct it is not correctly applied.
Kind regards
Jeroen
