[Requests] Homey Pro Community App Requests
What is the brand:
ATAG Zone / Ariston Remotethermo
What is/are the device(s)/service for type:
Heatpump / Boilers
What kind of category/signal(s) would the app use:
API from Ariston
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?
Are you willing to loan or donate to a developer?
Yes, donate money €/$/£.
Yes, willing to help with UAT and development(where I can)
Extra information:
I have this solution running from Home Assistant to Homey, but would love to get rid of Home Assistant.
What is the brand:
Maxitrol Remote Control B6R-H8TV4PWD
Examples:
Remote controler for Element4 gas fireplace
  • 868 Mhz;
https://www.element4.nl/downloads/7d47aee8-7622-41d1-a45d-f75ce6062a53
  • Yes, loan a device
  • Yes, donate money €
What is the brand:
FairyNest
Light
  • IP (Local/Cloud/WiFi);
Link(s) to where can this be found, the more information, the better.
  • Yes, donate a device
  • Yes, donate money €/$/£
Extra information:
What is the brand:
Sense - https://sense.com/
Examples:
-Energy Usage Monitor (multiple voltage clamps linked through WiFi device)
  • Bluetooth (BLE)
Link to GitHub repository for Home Assistant integration:
(core/homeassistant/components/sense at dev · home-assistant/core · GitHub)
What kind of device would you like to be added :
Alarm system panel app for envisalink module (ethernet to panel)
  • Brand , and id number(s) of device(s)
    DSC PowerSeries (1832, 1864) with Envisalink 4 module
    See http://www.eyezon.com/evl4.php
    What kind of category signal would the app use :
  • other ? (like) TCP/IP sending Hex ASCII
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
Yes, it’s extensive.
Are you willing to loan or donate a device to a developer?
  • Yes or No
    Yes.
What is the brand
HomeSeer
  • Switches/Dimmers with scene control and LED status lights
  • Motion Sensors
Z-Wave
The user guide lists all of the Z-Wave Command classes and Parameters
Their switches are great, and the feature to use the 7 LEDs each individually as status indicators is a great advantage over other switches.
Yes, I will donate developer and testing time.
Extra information:
I’m not actually looking for a developer, as by day, I’m a programmer, and this looks like it could be a fun little project to learn something new. But I don’t want to duplicate efforts if someone is already working on integrating the HomeSeer brand. Or if anyone has a project for similar devices that they may want to share to give me a head start.
I had a previous post here: https://community.homey.app/t/homeseer-hs-wx300
What is the brand:
Everhome.
  • LAN
  • 433 Mhz through gateway;
  • Yes
Extra information:
none
What is the brand:
Micronova/Agua-IOT/JollyMec
  • Bridge for:
    • Pellet Stove
  • Wifi / LAN
  • Yes, to loan the device will be a bit difficult :slight_smile: , but I am happy to donate in Euros or Dollars.
Extra information:
Micronova makes a Wifi Module which is called Agua-IOT for different brands of pelletstoves.
The all use a specific brandcode and brand url for the API. Brand codes and urls are in the repo from vincentwolsink. JollyMec is such a brand.
What is the brand:
Fujitsu
APP: Airstage
  • Heat pump
  • Airconditioning
  • Wifi, Cloud
  • Yes, donate money
What is the brand:
KMP
  • Pellet stoves
  • Pellet burners
  • WIFI, the products connect to KMPs portal via wifi.
Have asked KMP if any are available.
Portal can be found here: KMP Pellets kamin
Extra information:
None
Generic OCPP client
EV charger
Communicate with Cloud OCPP server
What is the brand:
NX Optix
IP camera recorder based on windows and linux even running on raspberry pi.
30 days free trial and compatible to almost every onvif camera and user friendly installation and app
installtion on raspberry pi
wget https://updates.networkoptix.com/default/38659/arm/nxwitness-server-5.1.4.38659-linux_arm32.deb
apt -f install ./nxwitness-server-5.1.4.38659-linux_arm32.deb
communicate direct by api to NVR and is able to receive images and motion detection and even to mark ad a bookmark to images by trigger or send camera PTZ command on trigger
https://meta.nxvms.com/doc/developers/api-tool/main?type=1&system=9
Donate
What is the brand:
Sagemcom.
ip TV receiver:
  • Infrared (IR);
No
  • No
Extra information:
This are the infrared HEX codes:
hex
Hex codes
1
sendir,1:1,1,55944,1,1,18,35,40,35,19,17,36,35,36,35,18,17,19,18,17,18,18,17,18,18,37,35,18,18,18,17,21,17,18,18,18,17,38,35,19,5603
0000 004A 0000 0012 0012 0023 0028 0023 0013 0011 0024 0023 0024 0023 0012 0011 0013 0012 0011 0012 0012 0011 0012 0012 0025 0023 0012 0012 0012 0011 0015 0011 0012 0012 0012 0011 0026 0023 0013 15E3
2
sendir,1:1,1,56140,1,1,18,35,36,35,18,18,36,35,40,35,22,17,18,18,18,18,19,17,18,18,36,35,18,18,19,18,18,18,17,18,41,36,35,5620
0000 0049 0000 0011 0012 0023 0024 0023 0012 0012 0024 0023 0028 0023 0016 0011 0012 0012 0012 0012 0013 0011 0012 0012 0024 0023 0012 0012 0013 0012 0012 0012 0011 0012 0029 0024 0023 15F4
3
sendir,1:1,1,55944,1,1,18,35,36,35,18,17,37,35,36,35,19,17,19,18,17,18,18,17,18,18,37,35,18,18,18,17,18,17,18,18,38,18,22,35,18,5620
0000 004A 0000 0012 0012 0023 0024 0023 0012 0011 0025 0023 0024 0023 0013 0011 0013 0012 0011 0012 0012 0011 0012 0012 0025 0023 0012 0012 0012 0011 0012 0011 0012 0012 0026 0012 0016 0023 0012 15F4
4
sendir,1:1,1,55944,1,1,18,35,36,35,19,17,36,35,39,35,18,17,18,18,17,18,18,17,18,18,36,35,18,18,18,17,19,17,38,35,18,17,38,5637
0000 004A 0000 0011 0012 0023 0024 0023 0013 0011 0024 0023 0027 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0024 0023 0012 0012 0012 0011 0013 0011 0026 0023 0012 0011 0026 1605
5
sendir,1:1,1,55944,1,1,18,35,36,35,18,17,36,35,36,35,18,17,18,18,17,18,19,17,18,18,17,18,19,17,21,18,17,18,18,18,37,35,36,35,38,5610
0000 004A 0000 0012 0012 0023 0024 0023 0012 0011 0024 0023 0024 0023 0012 0011 0012 0012 0011 0012 0013 0011 0012 0012 0011 0012 0013 0011 0015 0012 0011 0012 0012 0012 0025 0023 0024 0023 0026 15EA
6
sendir,1:1,1,55944,1,1,18,35,38,35,18,17,36,35,36,35,19,17,22,18,17,18,18,17,19,18,35,35,18,18,18,17,21,17,36,17,18,35,40,5637
0000 004A 0000 0011 0012 0023 0026 0023 0012 0011 0024 0023 0024 0023 0013 0011 0016 0012 0011 0012 0012 0011 0013 0012 0023 0023 0012 0012 0012 0011 0015 0011 0024 0011 0012 0023 0028 1605
7
sendir,1:1,1,55944,1,1,18,35,36,35,21,17,36,35,38,35,18,17,18,18,18,18,18,17,18,18,38,35,22,18,17,18,18,17,39,18,17,18,18,35,21,5594
0000 004A 0000 0012 0012 0023 0024 0023 0015 0011 0024 0023 0026 0023 0012 0011 0012 0012 0012 0012 0012 0011 0012 0012 0026 0023 0016 0012 0011 0012 0012 0011 0027 0012 0011 0012 0012 0023 0015 15DA
8
sendir,1:1,1,55944,1,1,18,35,36,35,18,17,36,35,38,35,18,17,19,18,17,18,18,17,18,18,35,35,20,18,19,17,37,35,18,17,18,17,37,5624
0000 004A 0000 0011 0012 0023 0024 0023 0012 0011 0024 0023 0026 0023 0012 0011 0013 0012 0011 0012 0012 0011 0012 0012 0023 0023 0014 0012 0013 0011 0025 0023 0012 0011 0012 0011 0025 15F8
9
sendir,1:1,1,56140,1,1,18,36,35,35,18,18,7,63,5,5,5,22,5,85,5,5633
0000 004A 0045 0000 0012 0023 0024 0023 0012 0011 0025 0023 0024 0023 0014 0011 0012 0011 0012 0012 0014 0011 0013 0012 0012 0011 0012 0011 0014 0012 0012 0011 0027 0023 0012 0011 0024 0023 0023 138E 0012 0023 0026 0023 0012 0011 0026 0023 0028 0023 0012 0011 0012 0012 0011 0012 0013 0011 0012 0012 0023 0023 0013 0012 0012 0011 0025 0023 0014 0011 0024 0023 0013 136A 0012 0023 002A 0023 0012 0011 0026 0023 0026 0023 0012 0011 0013 0012 0012 0012 0012 0011 0013 0012 0023 0023 0012 0012 0012 0011 0025 0023 0012 0011 0024 0023 0012 136A 0012 0023 0025 0023 0013 0011 0025 0023 0025 0023 0012 0011 0013 0012 0011 0012 0012 0011 0012 0012 0024 0023 0014 0012 0012 0011 0025 0023 0012 0011 0025 0023 0012 15E4
0
sendir,1:1,1,55944,1,1,18,35,36,35,19,17,36,35,38,35,18,17,18,18,17,18,18,17,18,18,35,35,18,18,18,18,36,35,37,36,37,5652
0000 004A 0000 0010 0012 0023 0024 0023 0013 0011 0024 0023 0026 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0023 0023 0012 0012 0012 0012 0024 0023 0025 0024 0025 1614
up
sendir,1:1,1,55749,1,1,18,35,36,35,21,18,35,35,38,35,18,17,18,18,17,18,20,17,18,18,36,35,19,18,17,18,35,18,20,35,19,18,35,5588
0000 004A 0000 0011 0012 0023 0024 0023 0015 0012 0023 0023 0026 0023 0012 0011 0012 0012 0011 0012 0014 0011 0012 0012 0024 0023 0013 0012 0011 0012 0023 0012 0014 0023 0013 0012 0023 15D4
down
sendir,1:1,1,55944,1,1,18,35,36,35,20,17,36,35,37,35,20,17,18,18,17,18,18,17,20,18,35,35,22,18,18,17,36,17,18,35,39,35,18,5658
0000 004A 0000 0011 0012 0023 0024 0023 0014 0011 0024 0023 0025 0023 0014 0011 0012 0012 0011 0012 0012 0011 0014 0012 0023 0023 0016 0012 0012 0011 0024 0011 0012 0023 0027 0023 0012 161A
left
sendir,1:1,1,55944,1,1,18,35,36,35,26,17,36,35,45,35,20,17,18,18,17,18,23,17,27,18,17,18,18,17,18,18,21,18,44,18,18,18,17,36,36,18,17,5631
0000 004A 0000 0013 0012 0023 0024 0023 001A 0011 0024 0023 002D 0023 0014 0011 0012 0012 0011 0012 0017 0011 001B 0012 0011 0012 0012 0011 0012 0012 0015 0012 002C 0012 0012 0012 0011 0024 0024 0012 0011 15FF
right
sendir,1:1,1,55944,1,1,18,35,36,35,19,17,37,35,36,35,18,17,18,18,17,18,18,17,18,18,37,35,18,18,35,35,20,18,18,17,18,17,36,5606
0000 004A 0000 0011 0012 0023 0024 0023 0013 0011 0025 0023 0024 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0025 0023 0012 0012 0023 0023 0014 0012 0012 0011 0012 0011 0024 15E6
ok
sendir,1:1,1,55944,1,1,18,35,38,35,18,18,35,35,36,36,17,18,18,18,17,18,18,17,18,18,35,36,15,18,16,18,16,37,5,33,5,5,5,8,5,18,11,5649
0000 004A 0000 0013 0012 0023 0026 0023 0012 0012 0023 0023 0024 0024 0011 0012 0012 0012 0011 0012 0012 0011 0012 0012 0023 0024 000F 0012 0010 0012 0010 0025 0005 0021 0005 0005 0005 0008 0005 0012 000B 1611
apps
sendir,1:1,1,55944,1,1,18,35,37,35,18,18,35,36,5,31,5,40,5,5,5,93,5,5664
0000 004A 0028 0000 0007 002E 0005 0005 0005 003F 0009 0028 000A 0005 0005 0031 0005 0008 0009 0047 0007 0005 0006 0016 0006 0005 0005 0044 0005 001C 0005 0008 0005 0005 0006 0041 0005 0027 000D 0005 0005 0041 0005 0005 0005 0005 0005 0058 0005 1359 0012 0023 002E 0023 0019 0012 0023 0023 0024 0023 0015 0011 0016 0012 0011 0012 0014 0011 0013 0012 0027 0023 0027 0023 0024 0012 0013 0012 0011 0024 0011 0012 0012 15DA
Back
0000 004A 0023 0000 0012 0023 0025 0023 0012 0011 0025 0023 0024 0023 0012 0011 0012 0012 0011 0012 0012 0011 0013 0012 0011 0012 0012 0011 0012 0012 0025 0023 0012 0012 0023 0012 0012 0023 0023 138E 0012 0023 0025 0023 0012 0011 0025 0023 0024 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0023 0023 0015 0012 0023 0023 0012 0012 0023 0012 0012 0023 0014 15E1
backwards
0000 0073 0018 0000 0020 0020 0020 0020 0022 0020 0041 0020 0021 0020 0020 0020 0022 0020 0023 003F 0045 0020 0020 0020 0021 0040 0021 0CAD 0020 0020 0021 0020 0021 0020 0040 0020 0021 0020 0021 0020 0020 0020 0021 003F 0043 0020 0020 0020 0021 0040 0020 0E20
forwards
0000 004A 0024 0000 0012 0023 0024 0023 0013 0011 0026 0023 0025 0023 0017 0011 0012 0012 0011 0012 0012 0011 0012 0012 0012 0012 0012 0011 0013 0012 0027 0012 0012 0011 0012 0023 0014 0012 0023 0012 0013 138E 0012 0023 0028 0023 0013 0011 0026 0023 0024 0023 0012 0011 0012 0012 0011 0012 0014 0011 0012 0012 0023 0023 0012 0012 0023 0012 0012 0011 0012 0023 0013 0012 0024 1606
external
0000 0068 001D 0000 0018 0018 001A 0018 0018 0408 0063 0018 0031 0018 0018 0018 0032 0018 0018 0018 0018 0018 0030 0017 001C 0017 0034 0017 0018 0018 0018 0018 0018 0018 0018 0408 0064 0018 0030 0018 001A 0018 0034 0018 0018 0018 001B 0018 0031 0017 001B 0017 0032 0017 0018 0018 0019 0018 0018 0018 0018 0FA8
gids
0000 004A 0010 0000 0012 0023 0024 0023 0016 0011 0024 0023 0029 0023 0012 0011 0015 0012 0012 0012 0012 0011 0012 0012 0023 0023 0015 0012 0023 0024 0029 0012 0015 0024 002B 15DB
menu
0000 004A 0022 0000 000A 0005 0005 0024 001E 0023 0012 0012 0021 0023 0023 0024 0012 0011 001A 0012 0011 0012 0012 0011 0013 0012 001C 0012 0012 0011 0024 0023 0030 0012 0012 0023 002C 0023 0024 137D 0012 0023 0024 0023 0012 0011 0024 0023 0025 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0024 0023 0024 0023 0026 0011 0012 0023 0024 0023 0013 15EC
netflix
0000 004A 0025 0000 0012 0023 0024 0023 0017 0012 0023 0023 0024 0024 0012 0011 0013 0012 0011 0012 0012 0011 0012 0012 0011 0012 0024 0024 0011 0012 0012 0012 0011 0012 0011 0012 0012 0012 0021 0013 000D 138E 0012 0023 002C 0023 0012 0012 0023 0023 0026 0024 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0023 0012 0011 0024 0011 0012 0012 0012 0011 0012 0011 0012 0012 0012 0023 15FC
opties
0000 004A 0010 0000 0012 0023 0026 0023 0012 0011 002A 0023 0024 0023 0015 0011 0014 0012 0011 0012 0012 0011 0013 0012 0023 0023 0013 0012 0023 0023 0026 0023 0024 0023 0012 161C
play pause
0000 004A 0010 0000 0012 0023 0024 0023 001B 0012 0027 0023 0027 0024 0012 0012 0011 0012 0010 0013 0010 0015 0005 0009 0005 0013 0005 0045 0005 0020 0007 002E 0008 0068 0005 15F1
program up
0000 004A 0023 0000 0012 0024 0023 0024 0011 0012 0022 0023 0023 0024 0013 0011 0012 0012 0011 0012 0012 0011 0012 0012 0013 0012 0015 0011 0012 0012 0027 0012 0012 0023 0012 0011 002F 0023 0026 13A0 0012 0023 0027 0023 0013 0011 0024 0023 0024 0023 0012 0011 0012 0012 0011 0012 0013 0011 0015 0012 0023 0023 0012 0012 0025 0012 0012 0023 0013 0011 0024 0023 0012 15F2
program down
0000 004A 0024 0000 0012 0023 0024 0023 0012 0011 0025 0023 0024 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0024 0012 0012 0011 0014 0023 0013 0012 0024 0012 0011 138E 0012 0023 0025 0023 0014 0011 0027 0023 0025 0023 0012 0011 0012 0012 0011 0012 0015 0011 0012 0012 0026 0023 0013 0012 0023 0012 0012 0011 0013 0023 0012 0012 0025 15E9
radio
0000 004A 0011 0000 0012 0023 0024 0023 0012 0011 0024 0023 0028 0023 0013 0011 0012 0012 0011 0012 0012 0011 0013 0012 0011 0012 0012 0011 0024 0023 0024 0023 0025 0012 0013 0023 0025 15FF
rec
0000 004A 0011 0000 0012 0023 0025 0023 0012 0012 0029 0023 002E 0023 0015 0011 0012 0012 0013 0012 0012 0011 0013 0012 0026 0023 0024 0023 0014 0012 0014 0012 0023 0012 0014 0023 001A 1605
search
0000 004A 0031 0000 0012 0023 002D 0023 0012 0011 0026 0023 0024 0023 0012 0011 0014 0012 0011 0012 0014 0011 0013 0012 0011 0012 0012 0011 0026 0023 0025 0011 0012 0023 0026 0011 0012 0012 0011 138E 0012 0023 0028 0023 0012 0011 0029 0023 0024 0023 0013 0011 0013 0012 0011 0012 0013 0011 0012 0012 0023 0023 0027 0023 0024 0011 0012 0023 0024 0011 0013 137C 0013 0023 0024 0023 0012 0011 0024 0023 0024 0023 0013 0011 0012 0012 0011 0012 0012 0011 0012 0012 0025 0024 0016 0030 0007 0007 0005 0021 0005 15F8
subs
0000 004A 0021 0000 0013 0023 0024 0023 001C 0012 0023 0023 002B 0023 0012 0011 0012 0012 0014 0012 001A 0011 0012 0012 0011 0012 0016 0011 0030 0023 0023 0024 0015 0011 0033 0023 0023 138E 0012 0023 0026 0023 0012 0011 0024 0023 0024 0023 0012 0011 0012 0012 0011 0012 0012 0011 0012 0012 0024 0023 0024 0023 0025 0023 0012 0011 0024 0023 0012 15F0
tv
0000 004A 0010 0000 0012 0023 0025 0023 0012 0012 0027 0023 0018 0012 0023 0024 0026 0023 0012 0012 0012 0011 0028 0023 0024 0023 0015 0011 0012 0012 0011 0012 0013 0011 0029 15E6
What is the brand:
Buderus (Bosch)
  • Heating
  • Thermostats
Can’t seem to find any information
  • No, i cant loan a device.
Extra information:
Part of Bosch group with Buderus MyMode app
My thermostat is the Logamatic TC 100.2
What is the brand:
Heimgard Wattle
Door Lock
  • Zigbee;
I have found this online wich i believe explains the capabilities, and possibly also the commands needed(?) Heimgard Technologies HT-SLM-2 control via MQTT | Zigbee2MQTT
I am in communication with the producer and they have said they will provide me with an API document wich i will share once received.
  • Yes, donate money - $100
  • I can´t share my lock sadly, but i have a homey cli set up on my computer and would be happy to test run the code, and if needed share my lock through teamviewer or something similiar.
What is the brand:
HerQs
Examples:
BBQ Thermometer
  • Bluetooth (BLE)
Not found
Extra information:
Device sold as HerQs in NL but can also be found in neutral version on AliExpress:
https://a.aliexpress.com/_EJjcWzH
What is the brand:
Simon 100 IO
  • Dimmer switch
  • Shutters
  • Shocket
  • Z-Wave
Extra information:
Abandoned app, hasn’t been updated in over a year.
Lamborgini CaloreClima
Your brand name.
*What is/are the device(s)/service for type:
Airco.
  • WiFI
  • Infrared (IR)
Don’t no.
NO NEED ANYMORE, FREE@HOME HAS A MATTER APP (EXTENSION HOW THEY CALL IT) FOR THERE SYSTEM ACCESS POINT, WHICH SUPPORTS SWITCHES, DIMMERS, BLINDS, FOR NOW.
What is the brand:
Free@home Busch-Jaeger
*Dimmer switch
*switch
  • IP Local API
Yes, there is already a Free@home app for Homey, but no dimmers, only dimmers have to be added.
  • Yes, ofcourse!
Extra information:
Free@home last updated 2 years ago, developer not responding to messages.
This topic has been cleaned up again. Just 3 duplicate requests which were deleted. :+1:t2:
Since the last cleanup in February 2023, the following 20 apps have been published in the App Store or devices have been added to existing apps:
– Xiaomi Mi Home (Xiaomi BLE Temperature and Humidity sensor with LCD)
– August Home
– Awtrix
– Sonnen / Sonnen Batterie
– Danfoss Ally
– Bestway Lay-Z Spa
– Balboa Spa
– TP-Link
– Mitsubishi (WF-RAC)
– OHMIGO
– Zonneplan one
– LG ThinQ
– Klink
– Legrand (Bticino/Legrand/Netatmo)
– Fyta
– Nibe
– Uponor Smatrix
– BlauHoff
– Flume
– Intex Spa
These requests have also been deleted from this topic. If you don’t see yours anymore, but your device(s) (still) isn’t supported? Please contact that developer first!
Thanks to all app developers!
