do you know a free test rstp link?
I get a lock icon on my settings without having set a pincode. Tried 0ās, but that didnāt work.
When you create a free account on https://rtsp.stream you get 2 links.
1920x1200
maybe you have set a pin in previous version?
Nope, unfortunately. But it also didnāt mention any added field message which we get since some time when updating.
Itās on both nspanel and android app.
I release an update with reset the pin code at 00000. After that it should work
Oke, can you supply the right nspanel apk after that. I am not able to go to the settings page to update since my settings are behind a pin .
If you recently made a backup, look in that json file. This pin logic existed technically before it was released this morning. You can read the code. Example:
āpinā:{āenabledā:0,ācodeā:ā00000ā}
you are all right! try to check in json backup.
Nspanel version is updated with a reset pin. You have to manual install it by bluetooth!
In a very early version i have added pin code, maybe you have insert some value and now it donāt match!
There was indeed a pincode active. I couldnāt remember about that old pin functionality (almost a year ago I started testing smartdash ). The Json file helped me figuring out the old pin. And a reset of the pincode is performed by the new version.
Sorry for my ābrokenā mind.
anyway i fixed a bug
Try the new update, maybe the position is fixed
Just tried, and the lock has come down
v 0.240508.5
- Added new VideoPlayer Widget for streaming video. It work with rtsp
Could you give any more details of how to configure, what are the preparations, what url do I have to useā¦
It work with a streaming url, like this:
rtsp://192.168.1.241:52969/86020cb8b310e898
The widget create a button that open in fullscreen the video streaming.
You can set a timeout for auto stop the play and you can use a boolean Homey variable for autostart the play
Which streaming software has been tested?
How do I get a rtsp url? Will this support Ring doorbell? Support for other devices?
@Robinjo has tested with Ring. Wait for him to reply.
I tried a reolink cam and it work,
rtsp://admin:[my_pass]@[my_cam_ip]:554/Preview_01_sub
Work in ns panel pro and a generic android device. iphone donāt work, unsupported url
Rebroadcast software for Ring I use Scrypted:
You can install it in docker for free if your nas supports it, mine is to old. So I installed the payed version desktop app on a mini mac. It cost 40 dollar/ year.
You have to set RTSP Parser to FFmpeg(UDP) to watch the rebroadcast URL in VLC player.
