[Pro][Dashboard] SmartDash - a dashboard for Homey [CLOSED]
Where did you get your NSPanel?
v 0.230918.1
Fixed thermostat widget: added support for tado and netatmo (need testing)
@RonnyW My bad. I was looking for something with .gif in it. Well learning something everyday :joy:.
But thanks for pointing me in de right direction.
Amazon?
v 0.230919.1
Fixed thermostat widget generic and tado. For netatmo need more testing.
Fixed some layout bugs
v 0.230921.2
Added some cosmetic options for widgets and panels
v 0.230922.4
Added feedback aptic
Using Smartdash for a while now. Mainly via my mounted NS panel pro. Tried several other options, but @diapolon is adding new stuff on the fly and with the new implementation without all kind of scripts and need of local api also installation is a piece of cake.
Just to give an impression how I use the possibilities.
Thankyou for feedback!
Need to add more icons for panel switch!
v 0.230922.5
  • Added customizable refresh time for widget camera
  • Added more icons for panel
v 0.230925.1
  • Added ability to lock a widget
  • Changed slider percentage position
v 0.230926.1
  • Fixed regression on create new widget
  • Rewrited sensor widget, now support these capabilities: alarm_contact, alarm_motion, alarm_tamper
v 0.230926.3
  • Added ability to change variable state with virtual button
v 0.230927.1
Added new backup system
v 0.230929.1
Added ability to hide widget title
I love this app on my NS Panel Pro! Thanks for creating it!
If I want to take a backup, which components do I need to install?
hi, thankyou!
For use backup you need a file manager, i tried some, and total commander work great.
For nspanel don’t use playstore version, use this: apk. It’s a version for nspanel pro with an update system
018468f776ad1140d82cd91fe606db0caefbd05c_2_374x374
v 0.231130.2
Added insight widget (experimental)
New database system
is it possible to use the application with homey 2019 ?
Tanks
the App work with a local API key, maybe with this guide
you can extract a key on previous homey platform
