[Pro][Dashboard] SmartDash - a dashboard for Homey [CLOSED]
Or this method
Homey does not yet provide an access token, however you can obtain one with the following steps.
  1. Open https://developer.athom.com/
  2. Press Login
  3. Open the browser dev tools → F12 and switch to the Network tab
  4. Log in with your Homey mail and password You should find a Get request “api/manager/sessions/session/me” which contains you local homey ip address if you are in the local network. Request URL: “https://LOCAL-HOMEY-IP.homey.homeylocal.com/api/manager/sessions/session/me” There you should fine something like the following under Request Header “authorization: Bearer 888999-19fe-4fa0-9999-b32982499999:9c1a21da-1df4-9999-8594-46fd7e799999:c6d7b6096df10a5fd2d8888888ff447ff1ca0e9c”
  5. Use the whole token after Beaer in that case it would be “888999-19fe-4fa0-9999-b32982499999:9c1a21da-1df4-9999-8594-46fd7e799999:c6d7b6096df10a5fd2d8888888ff447ff1ca0e9c”
