Octopus Energy API
Hey!
Has anyone managed to integrate with the octopus energy API?
Aydan
WhyAyden, did you get any progress on this? I too would love to be able to receive my cheap rates
Hello, no I did not :frowning:
I ended up going back to HomeAssistant as it was more what i wanted.
Thanks for replying, if I get anywhere i will let you know.
Hello, did you manage to make any progress?
Ok so I have made progress sort of. It is a long winded way but I have a solution. I got chat gPT to write me an application that I have running on a raspberry pi that sends an update every minute to mqtt stating the charge time slots and also wether the current minute is in cheap rate mode or not. I then use the MQTT client in homey.
Wow, impressive lateral thinking!
I got a Homey Pro to avoid having to fiddle with workarounds, Raspberry Pi, etc… but first impressions is it’s still far from plug 'n play.
Maybe it’s possible to retreive data with homeyscript.
Can someone try this, or explain how I get a temporary API key (not a customer here)?
const myAPIKey = 'abc123' // change into personal API key here
const url = 'https://api.octopus.energy/v1/accounts/';
const res = await fetch(url, {
              headers : {
              'x-api-key': myAPIKey
            if (!res.ok) {
              throw new Error(res.status);
              return false;
const json = await res.json();
//const value = json.value;
log (json);
return true;
I am currently out of the country until 1st September. I will be able to help then as I got chat GPT to do that but for me too. lol I have a copy of the code
Hi, I’m an Octopus customer, and have an API key, but I’m not a coder and am completely new to Homey Pro. I’ve installed the Homeyscript app, but not sure what to do next.
You can copy the code 1:1 by hitting the copy symbol:
Goto Homeyscript (https://my.homey.app/scripts)
Hit ā€œNew Homeyscriptā€, and paste the code in the top right screen, it should look similar to this:
Change the example API key in line 1 to your personal key;
Hit the blue Save button, and then the green ā€œRunā€ button next to it;
Now the results should show at the bottom screen, below ā€œConsoleā€
As you can see, I got error 401 returned, which means ā€˜unauthorised’ (invalid API key)
I hope this gets you going.
Thanks for your very detailed instructions… but unfortunately, I get exactly the same 401 error.
The URL https://api.octopus.energy/v1/accounts/ requires login credentials. So, do these need to be added to the script? (Sorry, I don’t really understand .json)
Yes, you’ll have to change the example API key abc123 in Line 1, into the API key you received:
Does that make any sense?
You can obtain your API key from your online dashboard (https://octopus.energy/dashboard/new/accounts/personal-details/api-access)
And, you’re welcome!
I am the same person that told you I have an API key.
I did use my own key, and when I got an error, I regenerated the key and tried again.
Sorry about that, forgot / did not read back the topic.
If you are sure your API key is valid, I don’t know what to test next.
One thing what might error: the single quotes ' ' are needed around your API key in line 1, don’t leave them out.
Make sure they’re not fancy quotes (cursive). Only straight quotes are valid.
Yes I double-checked, the syntax is correct. I’ve sent you a message.
Feel free to use this… just add the info at the top. I’ve still got some things I’m working on but might help get you started.
// Make sure you update below within the ' ' quotes.
const apiKey = ''; // Your API key
const accountNumber = ''; // Your account number, something like A-1234567
const electricityMPAN = ''; // You can get this from developers section
const electricitySerialNumber = ''; // You can get this from developers section
const gasMPRN = ''; // // You can get this from developers section
const gasSerialNumber = ''; // You can get this from developers section
const baseUrl = 'https://api.octopus.energy/v1';
function createAuthHeader(apiKey) {
    const authString = `${apiKey}:`;
    const authBase64 = Buffer.from(authString).toString('base64');
    return `Basic ${authBase64}`;
async function fetchAccountDetails() {
    const url = `${baseUrl}/accounts/${accountNumber}/`;
    try {
        const response = await fetch(url, {
            headers: {
                Authorization: createAuthHeader(apiKey)
        if (!response.ok) {
            throw new Error(`Error fetching account details: ${response.statusText}`);
        const data = await response.json();
        console.log('Account Details:', data);
        return data;
    } catch (error) {
        console.error('Error:', error);
async function fetchElectricityMeterData() {
    const url = `${baseUrl}/electricity-meter-points/${electricityMPAN}/meters/${electricitySerialNumber}/consumption/`;
    try {
            headers: {
        if (!response.ok) {
            throw new Error(`Error fetching electricity meter data: ${response.statusText}`);
        console.log('Electricity Meter Data:', data);
        return data;
    } catch (error) {
async function fetchGasMeterData() {
    const url = `${baseUrl}/gas-meter-points/${gasMPRN}/meters/${gasSerialNumber}/consumption/`;
    try {
            headers: {
        if (!response.ok) {
            throw new Error(`Error fetching gas meter data: ${response.statusText}`);
        console.log('Gas Meter Data:', data);
        return data;
    } catch (error) {
async function fetchBillingDetails() {
    const url = `${baseUrl}/billing/charges/`;
    try {
            headers: {
        if (!response.ok) {
            throw new Error(`Error fetching billing details: ${response.statusText}`);
        console.log('Billing Details:', data);
        return data;
    } catch (error) {
(async () => {
    await fetchAccountDetails();
//    await fetchElectricityMeterData();
//    await fetchGasMeterData();
//    await fetchBillingDetails();
What will this do exactly ?
Just had solar and battery installed and just started using octopus
Haven’t yet connected the inverter to homey but depending on what this does my next step is to find a way to adjust behaviour of the system and house to tariff info.
Would try homey if I can find a system that’s simple enough otherwise it’ll have to go on the HA
Thanks in advance.
Also like to know whst this does.
Would love to know if Giv Energy or Octopus R&D can be linked to Homey so that I can use solar automations without the hassle of Home Assistant.
There is an an app on Home Assistant called GivTCP which shows solar production and all sorts, be great to get that here and schedule my battery to charge depending on the time / unit price.
No clue where to start with designing such a thing for Homey but would be great if some clever minds come together to make this happen.
Thanks
Any update on what any of this is supposed to do?
All I can get it to give me is my address and the date I moved in. No other information so it’s pointless.
It doesn’t produce any energy data at all.
