MQTT Hub/Gateway
Hello HarriedeGroot,
I have started working on an application that runs anywhere, doesn’t rely on third party application and where you can create your logic in a flow manner, but kind of a mind map (like Visio flow chart with multiple triggers and multiple outputs).
The application is MQTT broker and client. It successfully receives MQTT messages from Homey. But how can I ask your app (with an MQTT message) to send all states (e.g. to get all devices with properties and states)?
Also, is there a way to get the available devices with states as a message (json object as payload with all info per device)?
  • Robert
