Indol / EVCO / Epoca EVLink in Homey?
Hi
I have a Indol EcoHeat waterheater with a Evco / Epoca EVLink wifi module, I’m wondering if there’s a way to intergrate it with Homey Pro?
BR
Kim
I have solved the connection between my Indol and Homey.
With help from Claude it was quite easy.
I added Homey in Claude with MCP.
BR Lars
You added the Indol to Claude and then took the info into Homey? No way to do it without Claude?
I added Homey MCP server into Claude. Then you can interact with Claude and explain what you would like to achieve. For ex. create one or more Scripts that can be copy and pasted into Homey. Claude can also create flows directly into Homey and much more.
If you want to learn more you can have a look at this video: https://www.youtube.com/watch?v=sHZETi15NVo or instructions for setting up Claude somewhere at Homey site.
Good Luck
I still don’t get how you use Indol in Homey? Is it a script?
Yes I use a script made by Claude. The script logs in to the cloud and can handle most of (all?) parameters that you can handle in the mobile app.
