Thanks @Adrian_Rockall I’ve added the new css to the first posts.
Wrapping of the flow names doens’t work anymore either, in your opening you have:
/* Make long flow names readable*/
.css-287q92-sc-ItemLabel {
white-space: pre-wrap;
Which I believe should be altered to:
.css-huzgua-sc-ItemLabel {
Thanks @Martijn_Hoogenbosch I’ve added it to the earlier posts.
If you include the following along with @Martijn_Hoogenbosch entries the row height will adjust to fit the text in:
.css-1lglkzi-sc-ItemDetails {
height: auto;
padding-top: 3px;
padding-bottom: 3px;
div.css-1yhvvkb-sc-ItemDetails {
height: auto;
padding-top: 3px;
I added the following:
.css-1b814yj-Button {
width: 95%;
To make sure the ‘and’ column also has a ‘better’ size.
Please do share!
awesome!
Here is my css. It is still under development (like my.homey.app). Keep in mind that the app is still beta and things will change (and definitely brak this css). Also this is based on my 27" screen. If you have a smaller screen you get less columns. The other tabs are also restyled.
:root {
--shadedbackground-color: ##ee;
--textcolor: #000;
--color-homeyname: #000;
--background-color: #fff;
--contextmenu-background-color: #444;
--default-button-color: #aaa;
@media (prefers-color-scheme: dark) {
body {
--color-white: #000;
--color-mono-100: #ffffff;
--color-mono-95: #FAFBFD;
--color-mono-90: #F1F2F6;
--color-mono-80: #e9eaee;
--color-mono-70: #DDDEE2;
--color-mono-60: #D1D2D5;
--color-mono-50: #c4c5c8;
--color-mono-40: #ACADB0;
--color-mono-30: #939496;
--color-mono-20: #7A7B7D;
--color-mono-15: #626264;
--color-mono-10: #49494A;
--color-mono-05: #313132;
--color-mono-02: rgb(255,255,255);
--color-mono-01: #0C0C0C;
--color-mono-0: #000;
--color-black: #000000;
--color-mono-o-02: rgba(255,255,255, 0.02);
--color-mono-o-10: rgba(255,255,255, 0.1);
--color-mono-o-50: rgba(255,255,255, 0.5);
--color-white-o-50: rgba(0,0,0,0.5);
--color-white-o-75: rgba(0,0,0,0.75);
--color-white-o-100: rgba(0,0,0,1);
--color-black-o-50: rgba(255,255,255,0.5);
--color-ice-white: #121319;
--color-night-black: #f6f7fb;
--color-text: var(--color-mono-0);
--color-text-light: var(--color-mono-0);
--color-text-light-hover: var(--color-mono-50);
--color-text-highlight: var(--color-blue);
--color-text-invert: var(--color-mono-0);
--color-text-invert-50: var(--color-white-o-50);
--color-text-disabled: var(--color-mono-30);
--color-text-inactive: var(--color-mono-20);
--color-line-light: var(--color-mono-10);
--color-background-hover: #999;
--color-component: rgb(50,50,50);
--shadedbackground-color: #fff;
--color-body: #000;
--textcolor: #fff;
--button-color:#fff;
--default-button-color: #fff;
/*--color-mono-100: #000; */
--color-text: #000;
--color-blue:#07f;
--color-highlight: #ff0;
--color-homeyname: #fff;
--icon-color-dark:#fff;
--color-icon-dark:#fff;
--background-color: rgb(30,30,30);
--contextmenu-background-color: #fff;
background-color: var(--background-color);
color: var(--textcolor);
.css-1yur33m-Base.e1smyq3q0,
.css-m338ur-DeviceTile-TopContainer.epcc9q43,
.css-1dpgz7t-Icon-Root.efypr2h0
.css-1py9yg8-tbody tr:hover,
.css-1py9yg8-tbody tr,
.css-1ip6r5q-DeviceCapabilityListItem-Label.e9o5z8t1,
.css-1pmd02-sc-Weather.e17mmtdn0,
.css-1ge3mo5-DeviceName.e8j0ho4 {
color: var(--color-mono-100);
.css-y80g9p-Title.e1ngchep0,
.css-14a3rl8-Title,
.css-1xqp3xf-Title,
.css-1xqp3xf-Title,
.css-15fy0ar-body2-CardTitle,
.css-ujc80q-Button-Root.e8sxues1{
.css-1293549-Container.e12emes70 > span.css-1dpgz7t-Icon-Root.efypr2h0
background-color: var(--color-mono-100);
.css-ujc80q-Button-Root.e8sxues1 {
background-color: var(--color-blue);
.e1im01um4 {
height: 22px;
.css-mes151-SearchField-Input {
background-color: var(--button-color);
.css-1dpgz7t-Icon-Root.efypr2h0 {
background-color: var(--button-color-text);
.css-15fy0ar-body2-CardTitle {
font-weight: bold;
font-size: 18px;
.css-1hu8qec-sc-Center {
width: 100%;
margin: 0px auto;
display: flex;
flex-direction: row;
justify-content: center;
.css-ppwutp-Section {
margin: 0px;
section.css-ppwutp-Section.e1s1bn0i5 {
width: 20%;
section.css-ppwutp-Section.e1s1bn0i5:last-of-type {
width: 60%;
display: flex;
flex-wrap: wrap;
height: fit-content;
flex: 1
.css-rrlt7p-Content.e1s1bn0i3 {
display: flex;
flex-wrap: wrap;
.flow-card {
margin: 10px;
font-size: 13px;
height: 120px;
width: 340px;
box-shadow: unset;
transition: unset;
.css-sib1sa-Nav-Container {
font-size: 12px;
.css-y1785u-sc-ItemRoot {
.css-sotwb8-sc-ItemDetails {
height: 22px;
.css-94pg0d-sc-ItemDetails:hover.eo5deeg4,
.css-huzgua-sc-ItemLabel eo5deeg4,
.css-sotwb8-sc-ItemDetails:hover, .css-94pg0d-sc-ItemDetails:hover {
background-color: transparent;
color:#fff;
.css-id2vso-sc-ItemDetails,
.css-94pg0d-sc-ItemDetails {
height: 22px;
.css-fcjpfp-sc-StickyActions {
padding-left: 40%;
margin-left: -60px;
.css-1xqp3xf-Title {
width: 100%;
.css-163q0dt-Root {
width: 100%;
.css-18garvg-Textarea, .css-fcjpfp-sc-StickyActions {
background: transparent;
.css-glpvqg-Button-Root {
background: var(--default-button-color);
.css-6mfsau-sc-Header e1csbp2v3 {
width: 70%;
max-width: 100%;
height: 40px;
.css-18garvg-Textarea.e1vsakk20 {
width: 70%;
height: 40px;
max-height: 40px;
border: none;
caret-color: var(--textcolor);
.css-a0trfj-Header-HomeyName.e1hl2b440 {
color: var(--color-homeyname);
.css-utgxvx-Button.e1s1bn0i0 {
margin-left: 10px;
margin-right: 10px;
width: 87%;
.css-6mfsau-sc-Header.e1csbp2v3 {
margin: 0;
border-bottom: 1px solid;
padding: 0 10%;
max-width: unset;
.css-oq2sid-Line.e1vsakk21 {
display: none;
.css-pi077z-sc-Button.et9mcxt0 {
color: var(--text-color);
font-size: 16px;
.css-mes151-SearchField-Input:not([value=""]), .css-mes151-SearchField-Input:focus {
.css-h40jet-overlay {
border-radius: var(--borderRadius-default);
.css-p2paa9-sc-Content {
padding: calc( var(--su-root) * 3 ) calc( var(--su-root) * 3 );
margin: 0 !important;
border-bottom: 1px solid !important;
padding: 0 10% !important;
max-width: unset !important;
position: fixed;
z-index: 999;
top: 80px;
opacity: 90%;
.css-1e8329n-Header-Container {
display: flex;
z-index: var(--zIndex-header);
margin-top: 20px;
margin-bottom: 20px;
flex: 0 0 40px;
-webkit-box-align: center;
align-items: center;
-webkit-box-pack: justify;
justify-content: space-between;
min-height: 0px;
.css-17owrf8-h3, .css-8uve29-DeviceTile-Header,
.css-1ulkaww-h1,
.css-9xi6tn-SectionTitle {
.css-12u75a7-Button-Root.e8sxues1 > span.css-1dpgz7t-Icon-Root.efypr2h0 {
background-color: var(--color-text)
.monaco-editor .margin
background-color: #E5D9BD;
monaco-editor, .monaco-editor .inputarea.ime-input {
background-color: #F5EACD;
.css-some1b,
.css-117q3uw-sc-Editor,
.monaco-editor, .monaco-editor-background, .monaco-editor .inputarea.ime-input {
div.view-lines {
padding-left: 0px;
left:4px;
.monaco-editor .inputarea {
border: none;
.current-line {
background-color:#FFFACD;
border: none;
.monaco-editor .view-overlays {
padding-left: 0px;
left: 4px;
.view-overlays div, .cigr,.cigra {
padding-left: 0px;
left:0px;
.css-1jzbmsj-FlowCardHint-Icon.e5jasbj1 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-1yj6fto-CardIcon.e1nu42g86 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-1yv6hw9-CardIcon.e1nu42g86 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-1ck9etg-CardIcon.e1nu42g86 > span.css-1dpgz7t-Icon-Root.efypr2h0 {
background-color: black;
.css-ujc80q-Button-Root.e8sxues1 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-gfqu3y-BorderWrapper.e1syuo1q1 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.e1nu42g81 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-e0b41j-CardIcon.e1nu42g86 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-19e7a1o-CardIcon.e1nu42g86 > span.css-1dpgz7t-Icon-Root.efypr2h0,
.css-qswy13-CardIcon.e1nu42g86 > span.css-1dpgz7t-Icon-Root.efypr2h0 {
background-color: white;
.css-glpvqg-Button-Root.e8sxues1 > span.css-1dpgz7t-Icon-Root.efypr2h0 {
background-color: #0b0;
.css-os8dre-RoundWrapper {
background-color: unset;
.css-os8dre-RoundWrapper.e1syuo1q0 > span.css-1dpgz7t-Icon-Root.efypr2h0 {
.eozj5ct2.css-1l95172-Icon-Root-MoreButtonIcon.efypr2h0,
.e1nu42g81 {
opacity: unset;
transform: rotate(-90deg);
.css-8zfs37-sc-ItemContextMenuButton,
.css-8zfs37-sc-ItemContextMenuButton.eo5deeg1 {
visibility: hidden;
.css-19ku62l-sc-ItemContextMenuButton.eo5deeg1 {
visibility: visible;
.css-4d1u4p-ActionButton:hover,
.eozj5ct2.css-1l95172-Icon-Root-MoreButtonIcon.efypr2h0:hover,
.e1nu42g81:hover {
opacity: 0.5;
.eozj5ct2.css-1l95172-Icon-Root-MoreButtonIcon.efypr2h0 {
.css-uf4jfm-sc-Extension.e1im01um6 {
color: var(--color-mono-30);;
.css-1jzbmsj-FlowCardHint-Icon {
background-color:white;
border-radius: 6px;
padding:0;
margin-left: 4px;
transform: translateY(-10px);
border: 1px solid #fff;
.css-oz5z5j-ZoneActivity.e1mg4iro0
color: var(--color-mono-20);
.css-19rj6pl-IndicatorLightContainer {
background-color: rgba(255,255,0,1);
.css-fplr7v-DeviceTile-Root[value="false"] {
opacity: 0.15;
background-color: var(--color-mono-0);
.css-tyf752-Base.e1smyq3q0 {
background-color: var(--color-mono-20);
.css-l7bkth-h2.e1cp72ro3,
.css-l9bkth-h2.e1cp72ro3,
.css-1m5m9vt-body1.e1cp72ro1 {
button[disabled] {
background-color:var(--color-mono-30);;
.css-utgxvx-Button.e1s1bn0i0:hover,
.css-glpvqg-Button-Root.e8sxues1:hover,
.css-glpvqg-Button-Root.e8sxues1:hover {
color: var(--color-text-light);
background-color: var(--color-mono-95);
transform: scale(1.01);
opacity: 0.8;
.css-1e2ljcw-Unit.e1b4rrb93,
.css-d9fda6-SectionSubTitle.e1sgjjj32 {
color: var(--color-mono-15)
And how did you manage to get the black theme? Is that a browser theme?
Yes, my browser is in dark mode. On windows you have to set windows in dark mode
I will look into this, this evening. I must have missed some classes
I have modified the css a little. Not everything is correct but things will break when Athom deploys a new version.
If you like this darkmode theme but don’t want windows in dark mode, you can remove the
@media query around the body block starting at line 10 and ending at line 68 (but keep body block)
:root {
--textcolor: #000;
body {
--color-line:#5a5a5a;
--input-border:var(--color-line);
--color-body: #000;
--textcolor: #fff;
--color-text: #000;
--color-blue:#07f;
.css-2ld8rn-SearchField-Input,
.css-14a3rl8-Title,
.css-1xqp3xf-Title,
.css-1xqp3xf-Title,
.e1im01um4 {
height: 22px;
font-weight: bold;
font-size: 18px;
width: 100%;
margin: 0px auto;
display: flex;
margin: 0px;
width: 20%;
width: 60%;
display: flex;
flex-wrap: wrap;
flex: 1
display: flex;
flex-wrap: wrap;
.flow-card {
margin: 10px;
font-size: 13px;
height: 120px;
width: 340px;
box-shadow: unset;
transition: unset;
font-size: 12px;
height: 22px;
color:#fff;
height: 22px;
padding-left: 40%;
margin-left: -60px;
width: 100%;
.css-163q0dt-Root {
width: 100%;
width: 70%;
max-width: 100%;
height: 40px;
width: 70%;
height: 40px;
max-height: 40px;
border: none;
margin-left: 10px;
margin-right: 10px;
width: 87%;
margin: 0;
padding: 0 10%;
max-width: unset;
display: none;
font-size: 16px;
position: fixed;
z-index: 999;
top: 80px;
opacity: 90%;
display: flex;
margin-top: 20px;
flex: 0 0 40px;
min-height: 0px;
.css-1ulkaww-h1,
.css-some1b,
div.view-lines {
padding-left: 0px;
left:4px;
border: none;
.current-line {
border: none;
padding-left: 0px;
left: 4px;
padding-left: 0px;
left:0px;
.css-1troxg2-sc-IconWrapper,
.css-1pbk2nf-CardIcon.e1nu42g86 {
.css-1ru0ags-sc-Heading,
.css-bj5rw5-ArgumentBase,
.css-a4os0a-body2-sc-CardTitle {
.css-1gm55sn-sc-IconWrapper > span:first-of-type,
.css-1ew1tjp-sc-CardIcon > span:first-of-type,
.css-1oyvl1c-sc-IconWrapper > span:first-of-type,
.css-1cyeuzb-sc-IconWrapper > span:first-of-type,
.css-1l6izd9-sc-IconWrapper > span:first-of-type,
.css-1rl3tat-sc-IconWrapper > span:first-of-type,
.css-1b44zfx-CardIcon > span:first-of-type,
.css-psqvu2-sc-CardIcon > span:first-of-type,
.css-d4oq54-sc-IconWrapper > span:first-of-type,
.css-zru3em-sc-IconWrapper > span:first-of-type,
.css-1kn59xg-sc-IconWrapper > span:first-of-type,
.css-1troxg2-sc-IconWrapper > span:first-of-type,
.css-1171vma-sc-CardIcon > span:first-of-type,
.css-1badi50-CardIcon > span:first-of-type,
.css-1pbk2nf-CardIcon > span:first-of-type,
.css-1jzbmsj-FlowCardHint-Icon.e5jasbj1 > span:first-of-type,
.css-1yj6fto-CardIcon > span:first-of-type,
.css-1yv6hw9-CardIcon > span:first-of-type,
.css-1ck9etg-CardIcon > span:first-of-type {
.css-1psktj1-sc-CardIcon > span:first-of-type,
.css-1utjvo4-sc-IconWrapper > span:first-of-type,
.css-mb7rd8-sc-CardIcon > span:first-of-type,
.css-1gxhbu4-sc-IconWrapper > span:first-of-type,
.css-h3555p-sc-IconWrapper > span:first-of-type,
.css-64uawx-sc-CardIcon > span:first-of-type,
.css-1yvfyp7-sc-IconWrapper > span:first-of-type,
.css-1jxfsgp-sc-CardIcon > span:first-of-type,
.css-42u0cj-sc-IconWrapper > span:first-of-type,
.css-s77mou-sc-IconWrapper > span:first-of-type,
.css-vzdp8n-sc-CardIcon > span:first-of-type,
.css-1xct97i-sc-IconWrapper > span:first-of-type,
.css-uubfww-sc-IconWrapper > span:first-of-type,
.css-emsjvp-sc-IconWrapper > span:first-of-type,
.css-1v9un48-sc-CardIcon > span:first-of-type,
.css-2ew1tjp-sc-CardIcon > span:first-of-type,
.css-1qlxmu0-ArgumentBase.ekk9fzm0,
.css-onw83h-CardIcon > span:first-of-type,
.css-onw83h-IconWrapper > span:first-of-type,
.css-u7w57-sc-IconWrapper > span:first-of-type,
.css-19i8b2z-sc-IconWrapper > span:first-of-type,
.css-12yp2rj-CardIcon > span:first-of-type,
.css-18m61nk-CardIcon > span:first-of-type,
.css-nns3x8-CardIcon > span:first-of-type,
.css-8q1vlr-CardIcon > span:first-of-type,
.css-1i4ezcc-CardIcon > span:first-of-type,
.css-eli0cn-CardIcon > span:first-of-type,
.css-ujc80q-Button-Root.e8sxues1 > span:first-of-type,
.css-gfqu3y-BorderWrapper.e1syuo1q1 > span:first-of-type,
.css-e0b41j-CardIcon > span:first-of-type,
.css-19e7a1o-CardIcon > span:first-of-type,
.css-qswy13-CardIcon > span:first-of-type {
.e1nu42g81 {
opacity: unset;
visibility: hidden;
.e1nu42g81:hover {
opacity: 0.5;
border-radius: 6px;
padding:0;
margin-left: 4px;
opacity: 0.15;
button[disabled] {
opacity: 0.8;
.css-gxn0rm-sc-Header {
background-color: var(--color-mono-10);
.css-ujc80q-Button-Root.e8sxues1 > .css-1ly55jo-value.e19mul4b0 {
background-color:transparent;
color: white;
Please use the </> (when having the code selected) button! when posting such long code next time (it will put it in a nice box), for now I have done it for you to keep the topic clean.
You’ve done it before with ```, so you know how it can work (too).
Ok, thanx
And it’s gone again. Is there also a way to make this more reliable? Every new version of the app changes the whole layout.
Nope, Athom could making it a lot user friendly when they stop changing the names/ids, but they know that, cause… well they know what users want.
Do i miss something here?
/* Show flows in landscape */
.css-14scrpd {
width: 100%;
display: flex;
.css-1ab8s7t {
width: 33%;
/* Adjust flowcards width for landcape view */
.css-2gc5z4 {
width: 95%;
.css-1iuu5lg {
width: 82%;
Added 2 more Classes and added it to the opening post(s), thanks!
