What kind of device would you like to be added :
The online
Brand , and id number(s) of device(s)
What kind of category signal would the app use :
Zwave,
Zigbee,
IR,
public service? (like a Weather or postal service )
other ? (like)
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
Renault ZOE is an electrical car.
With the Renault app it is possible to start the loading, ask battery information, start preconditioning
etcâŚ
All information in https://github.com/edent/Renault-Zoe-API
Are you willing to loan or donate a device to a developer?
Devices have replaced light wall switches so cannot be removed, happy to probe\test as required.
Explanation
This light switch was produced in response to the issue that turning off a physical light switch kills the power to the Yeelight ceiling smart light making it inoperable, it provides a hidden power switch (for power on reset) and replicates the provided remote controls functions via bluetooth. (On\Off, Moon mode, dim, color temp change). The device pairs to the light(s) exactly as the hand remote does so protocol may be identical.
GPS-2000 (only one type of switch)
Zwave,
Not public, but I have have access to full documentation
Where can this be found?
Please contact me at adrian@liteautomation.com.au or Naor Gerber from Gerber Prime Technologies at naor@gerber-com.net
Yes, send samples and pay for time to develop app.
Leaksmart shutoff valve and sensors
Brand Leaksmart
See - https://leaksmart.com/
Leaksmart Cut-in valve (all pipe sizes)
Leaksmart Sensor
Leaksmart Hub 3.0 What kind of category signal would the app use :
The valve, sensors and hub communicate via Zigbee. The valve and sensors being Zigbee can be directly connected to any Zigbee hub e.g. Smartthings, Wink, Hubitat without going via the LeakSmart hub.
Zigbee,
The Hub 3.0 communicates via WiFi to the Internet and locally
It does not appear so as of yet. See the comment about them using standard Zigbee.
It will I suspect not help but several of the other smart hub platforms have their apps for managing LeakSmart on github. I strongly suspect these all communicate directly via Zigbee rather than the hub.
Alarm system panel
DSC PowerSeries (1555, 1555 MX, 5010 (832), 5020 (864), 1616, 1832, 1864)
with Envisalink 3 or 4 module
See http://www.eyezon.com/evl4.php What kind of category signal would the app use :
other ? (like) TCP/IP
Yes
Note: Whilst there seems to be an app for linking to a DSC panel fitted with the Konnected! module that approach is limited to wired only sensors and would seem to also preclude having the panel monitored by a security company. The Envisalink supports all supports sensors including wireless. It basically acts as a serial to ethernet convertor and leaves the rest of the panel untouched and hence still monitor-able. I would therefore prefer the Envisalink approach.
