Feature request: Presence trigger flow cards with duration
It would be great if the presence trigger flow cards got some variants that took duration into account. For instance… “First person came home and stayed home for X seconds/minutes”
Use case:
My wife works close by our home and will often pass it while at work. Some flows don’t actually need to run when she is only “home” for 2 minutes. Also many flows are standard flows, that I don’t want to be advanced flows, even if I could solve it by using those.
The Better Logic Library app had flowcards for x stayed x for x period.
Youcould use those. Set the variable to true when the first person comes home and to false when she/he leaves.
Thank you. That sounds like a good tip. I’ll have a look and see if I can get to work.
I would still like it to be a built in feature of Homey and not have to rely on Better Logic Library though.
It’s not implementing this for the native presence functionality of Homey, but actually I just implemented this into the “alternative” - Smart Presence | Homey
Version 0.9.17 — Added duration-based arrival and departure Flow triggers for users, household members, kids and guests, including first-arrival and last-departure variants with selectable seconds or minutes.
Thank you. I’ll have a look. Sounds like it’s just the functionality I need.
Venlig hilsen
Jon Hye-Knudsen
