Hi there, first of all, i’m a very noob in dev… sorry for that.
What i want to achieve is adding a custom capability that sends a zwave value to my device, because the capability doesn’t existe in homey apps-reference.
I’m not sure where to declare the method, i need to create a /drivers/my_driver/device.js right?
Thanks for your response. I’ve already read those docs, and it’s not very clear to understand where to write what.
But nevermind, i’ve realised i don’t need a custom capability. thanks again.
Hi again,
I’ve got a problem to set a zwave device parameter. When i change the choice’s picker in the UI, nothing happens.
Here is my GET and SET in drivers/device/driver.js:
pilot: {
command_class: 'COMMAND_CLASS_SWITCH_MULTILEVEL',
command_get: 'SWITCH_MULTILEVEL_GET',
command_report: 'SWITCH_MULTILEVEL_SET',
command_report_parser: report => {
console.log('report', report)
return report['Value'];
Here is the capabilty enum in app.json:
"pilot": {
"type": "enum",
"title": {
"en": "Mode"
"getable": true,
"setable": true,
"values": [
"id": "99",
"title": { "en": "Comfort"}
"id": "30",
"title": {"en": "eco"}
"id": "0",
"title": {"en": "off"}
Isn’t the enum id of the value that is sending to the device?
The device doc show that:
The center column is the zwave value.
My device classes are GENERIC_TYPE_SWITCH_MULTILEVEL and SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
It seems there is a communication pb between Homey and the device. When i pick a choice in the app, there is a timout error after a few seconds.
The route seems KO:
but the device is at 20 cm from Homey. The pairing is ok, i don’t move the device after pairing. This device is the only zwave one and isn’t on battery.
Send Basic On seems ok:
[2019-09-28T19:54:24.603Z] Command[388] start: sendData
[2019-09-28T19:54:24.610Z] ProcessSendData[325]: To node: 22 with data: 0x2001ff and txOptions: AUTO_ROUTE
[2019-09-28T19:54:24.622Z] Command[388] end: sendData
But not the Heal command:
| 2019-09-28T19:55:46.019Z |
Command[389] start: heal |
| 2019-09-28T19:55:46.089Z |
Node[22]: Received application update: 0x11015e86598572985a227356ef5e8659857298 |
| 2019-09-28T19:55:51.030Z |
ProcessHeal[326]: Error: request_timeout |
| 2019-09-28T19:55:51.032Z |
Command[389] end: heal |
Any thoughts?
Ok, i’ve done a factory reset to the device, the zwave mesh seems ok, all tests are good.
So i’m back to my 30000 ms timeout problem when i change the picker in the app.
