I have bought one the smartthings hubs from RACV and although it is just the mesh system + smartthings and not the full hub, so far it is pretty great. There are Samsung plugins that cover most things, then there are community plugins, then you can modify community plugins or create your own. The coverage is huge and so is the flexibility.
Scripting can be done on the app or you can create a type of mini app on the web interface with logic built in.
I haven’t found anything that doesn’t have a plugin yet.
Z-wave coverage is very good and device and product codes can be changed on the fly.
Response times are instantaneous.
The apps leave a bit to be desired but they are in a transition phase, this is the way to go IMO if starting from scratch.
I will hold on a little longer and keep using both, I have a lot of devices and don’t look forward to another transition.
