BLL to extract webhook body
Hi all,
Sorry for the noob question but I’ve got a webhook body and I’d like to extract some info from it.
{"response_id":"15","created_at":"2024-11-22T19:59:17.554Z","form_id":"xxxxx","form_name":"xxxx","workspace_id":"yyyyy","timezone":"Europe/Amsterdam","page_url":"zzzzzzz,"test":false,"workflow_data":[],"response_data":{"From (number)":[{"label":"NAME","value":"NUMBER"}],"Message":"IMPUT"}}
I need:
“value”:“NUMBER”
“Message”:“IMPUT”
I have BLL, but don’t know how to get it to do the above.
Thanks very much on all the advice on how to get there!
Use these standard logic THEN cards:
And set JSON path to:
response_data[“From (number)”][0].label
response_data.Message
And please post JSON as “code” to keep simple " " signs
grafik
Thanks for your quick response! Forgot about those!
response_data[“From (number)”][0].label gave me the following error
Lexical error on line 1. Unrecognized text.
$.response_data[“From (number)”][0].
response_data.Message gave me the full body again, not the Message part.
Please try again with this code format that. Perhaps your browser exchanged the douoble quotes with unicode characters.
response_data["From (number)"][0].label
Still the same error for the number.
But a correction at the message part. There the response is:
{“event”:“R1”,“data1”:“field2”,“data2”:“field3”}
Which is still confusing.
Also to add,
The trigger is the community app Webhooks.
This bc I could not let the Logic Webhook module to be triggered by Formcrafts.
But I will give that one another try in the morning.
So I managed to configure the logic Webhook receive module.
Unfortunately It can only handle 1 card, so therefore I now pas it through a no-code platform.
Now I need to split the string based on the “|”
Any suggestions?
Couple of trials and errors and with some help of Perplexity AI, I managed to get it right!
Thanks all!
