Apple TV app created!
Tested the new version. On the challenging Apple TV, it runs into an on off loop. Turns on, and off every second. (All flows relating to the ATV disabled).
When App indicates that the ATV is on, there is still no lights on the ATV box.
@mhemil oops, that does indeed look like a bug, let me dive into that code for a while :slight_smile:
Thanks for reporting!
Best regards,
David
@Lis_Hatgi Sure it’s a link a couple of message above here! (9 days ago)
//David
f9302710-84dc-4164-b425-151121f551b4
@mhemil - Thanks, already working on a fix :slight_smile:
//David
@mhemil - Ok, new version uploaded! That should solve the issues with the power state flapping and false activation after turning off!
Have a nice evening!
//David
@Mojento Excellent! The Power state swapping stopped immediately after the new version was uploaded! Much appreciated :folded_hands:t2:
On/off works for the Ethernet connected ATV, but the WiFi connected receives a time out error.
Hi @mhemil
Ok, that’s odd, can you send me a diagnostic report so I can see a little bit more details?
Thanks!
Best regards,
David
Here it is: 13a69cb9-bf5d-478d-8ea4-7d7834f59f0c
@mhemil How’s the WiFi where the ATV is? from the logs it seems your ATV is struggling to respond within reasonable timeframe. the port is open, but the ATV is not responding and then gives the timeout message. Can you try to restart the ATV (settings → system → restart) and try the turn off/on it.
I will dig deeper into this tomorrow :slight_smile:
Best regards,
David
I like to see widget added and like Sonos can we have a option for using a soundboard sound played on them
@mhemil - Ok, a new version is uploaded, please test when available and let me know if that solves the issues.
Best regards,
David
@Mojento = Is it possible that we can have a card "Then” to play a specific track/music or playlist? I would like my mini pods to play a specific track whenever someone rings the doorbell, in addition to being able to trigger specific playlists for different “chilling” conditions.
Cheers
Hi, first of all I want to thank you for creating this app. I want to ask if I’m the only one with the issue that my lamps (Philips Hue Play Bar, GU10 and E14) turn on randomly. After restarting the app, no issues for couple of days. After a couple of days, same issue again. Is this a structural solution for this issue?
Maybe you‘re in the false topic?:face_with_monocle:
@DayLei There are two Apple TV apps, one of which is in the Homey store. So it depends on which one you’re using. Is it the “Apple TV” or “Apple TV & HomePod” app?
In case it’s the second one, this is the wrong topic and you should post your bug in this topic instead: https://community.homey.app/t/app-pro-apple-tv-homepod/
Hi Bas, thanks for your reply. I’m using the Apple TV app Experimental version 1.0.7.
