[APP] Tuya - Smart Life. Smart Living
I also have the Moodlights but in my case they’re still working fine. The device becoming unavailable after setting it is often caused by the device being offline. Does it still work in the Smart Life mobile app? If it needs a Bluetooth connection, then it has lost it’s WiFi connection and will try to find the device via Bluetooth to be able to control the devices even if your internet connection is down. So you need to reset your device I think
I still have problems. I have added a virtual switch that is switched every hour, if it does not respond tuya will restart. I get a notification if this happens. Every night at 0400 tuya is restarted and occasionally once throughout the day.
I have som Tuya WiFi curtain motor (Emteco), imported through the official Tuya app, shows two simultaneous capabilities once imported into Homey: position percentage (not supported by the motor), and open, close and stop.
When exported to HomeKit, Homey exposes the percentage capability, which makes the device unresponsive in Apple Home, since that capability does not actually work on the motor. What is needed is for the device to be exposed only as open, close, stop.
The motor was imported and exported, tested and validated in Home Assistant, using the original Tuya configuration and the export app built into Home Assistant. It shows correctly on HomeKit and works.
Help Tuya app just randomly crashing ec587a9e-25e8-4e3f-8b49-6ab7526a1964
Was hopping this community was more active, even being tuya the largest smart device platform we dont have support, I´m afraid gona have to ditch my homey.
Which Homekit bridge do you use? HomeKit experiment or the HomeKitty community app? While I don’t use any Apple devices, I’ve read that the HomeKitty community app works better.
I have six identical EMTECO/Tuya Wi-Fi blinds that work perfectly inside Homey:
Up → Open
Idle → Stop
Down → Close
The problem is Apple Home integration.
I have tested Matter Bridge, HomeKit Experiment, and other available HomeKit bridging methods/configurations. In every case the result is the same:
The blinds are successfully exposed to Apple Home, appear correctly as window coverings, but ZERO commands from Apple Home operate them.
Open, close and position control do absolutely nothing, while the same blinds continue to work immediately from Homey.
I have spent hours testing bridges, configurations, pairing, Matter, HomeKit, networking and Tuya. I am not looking for another workaround, virtual device or custom Flow.
If the Tuya driver exposes the wrong capabilities, it should be fixed. If Matter Bridge/HomeKit Experiment maps them incorrectly, that should be fixed. And if the device is incompatible, Homey should not expose it as a functional window covering.
What I am asking for is identification of the broken layer and a proper fix — not another workaround around an incomplete implementation.
I can provide the complete Tuya DPs, Homey capabilities and diagnostics needed to reproduce the issue.
Magnum MRC: temperature setpoint changes outside Homey are immediately reverted
I use a Magnum MRC thermostat in Manual mode, connected through the latest version of the official Tuya app for Homey.
When I change the target temperature on the physical thermostat or in the Tuya Smart app, the new value appears briefly and reverts to the previous value within one second. Changing the temperature through Homey works correctly.
If I stop the Tuya app in Homey, changes made on the thermostat or in Tuya Smart remain in place. When I restart the Homey Tuya app, Homey correctly picks up the updated setpoint. However, subsequent changes made outside Homey are immediately reverted again.
Could you investigate whether the integration writes the previous setpoint back to the thermostat when it receives a setpoint change?
Device support request: Gardenreet Bluetooth lighting through GW018-DM — color and brightness controls
I’m requesting support for Gardenreet Bluetooth landscape lights connected through a Tuya GW018-DM gateway. I have 17 of these lights, and Homey discovers them, but they appear as Other devices without normal lighting controls.
My goal is to use Homey to choose each bulb’s color, shade/saturation, and brightness, then combine those settings into Flows and lighting scenes. I would prefer to use your existing integration if it can support them.
We have completed several small, physically observed tests and identified working color commands through a separate Tuya API. I’ve included the findings below to help establish whether this can be supported within com.tuya2. I’m not assuming this is simply a missing device mapping or an easy change.
Homey version
Homey Pro (2026), firmware 13.5.2. Verified October 19, 2026.
Tuya app version
com.tuya2 v1.5.12. This also matched main/app.json when checked on October 19, 2026.
App diagnostics report ID
4775648a-7d21-4e39-8bcf-7fcef7e13805
Generated from the installed Tuya app’s Create Diagnostics Report action on October 19, 2026, with a description of this issue.
Description
Devices and current behavior
Device Model / product Tuya category
Gateway GW018-DM; product dmmv7eacvbyyg9gl wg2
Gardenreet bulbs Product vd8o60wy; product name Smart LED Light dj
All 17 bulbs share that bulb product ID. In Homey they are imported through the Other driver with no lighting capabilities. The representative bulb’s reported status is an empty array.
The generic Boolean, Number, String, and JSON command cards are available, but command-code autocomplete says “No available codes found.”
What we tested in the existing Homey integration
On one representative bulb:
  • Manually entering switch_led in the Boolean card successfully turned it off and back on.
  • Sending colour_data_raw with value AABkMg== through the String card returned: Tuya error: Command or value unsupported.
  • Sending bright_value_v2=500 through the Number card was accepted, but the purple bulb became cool white instead of becoming dimmer purple.
  • Sending work_mode=colour through the String card successfully restored the previously stored purple.
The changes described above were observed at the physical bulb, not inferred solely from API success responses.
Expected behavior
Native on/off, color, saturation, and brightness controls, with brightness preserving the selected color. These would let me create per-bulb lighting scenes and use them in Homey Flows.
Device specification
I retrieved the Device Specification from the installed app. The device is already added as Other, but both specifications and data_points show <not available>.
This is a sanitized excerpt, not the full original device object. Device/account identifiers, location fields, and the local_key field have been omitted. The empty status and unavailable values are exactly what the installed app returned:
  "device": {
    "category": "dj",
    "model": "",
    "product_id": "vd8o60wy",
    "product_name": "Smart LED Light",
    "sub": true,
    "status": []
  "specifications": "<not available>",
  "data_points": "<not available>"
I followed the Other pairing route to check whether a fresh entry could retrieve the specification without removing the original. None of the existing Gardenreet bulbs was offered; only the unrelated Pool lights device appeared. I canceled without adding anything. The inventory remained at 85 devices, with no devices added or removed.
A source review identified a relevant limitation: in v1.5.12, drivers/other/driver.ts passes undefined for both specification arguments when constructing the device properties. The base driver then renders these as <not available>. The Other path does not attempt specification retrieval. Separately, the base pairing driver currently leaves data-point retrieval disabled.
This explains why the Other device cannot supply the full specification requested by the reporting guide; it does not establish that Tuya would refuse a specification request. Could you advise a supported way to obtain the specification for an existing Other device, or accept the developer-platform findings below as supplementary evidence?
Source references:
Both files matched main when checked. No existing bulb was removed, reset or re-paired.
Supporting findings: working color and brightness commands
The developer platform identifies these relevant data points:
DP Code Meaning
1 switch_led On/off
2 work_mode white / colour / scene / music
3 bright_value 10–1000; exposed as bright_value_v2 in the standard commands
11 colour_data_raw Raw color control
Through an existing Tuya developer project, this endpoint successfully changed the representative bulb’s color and brightness:
POST /v2.0/cloud/thing/DEVICE_ID/shadow/properties/issue
Example request body for red at 50%:
{"properties":"{\"colour_data_raw\":\"AABkMg==\"}"}
The tested DP11 encoding is Base64 of four bytes:
[hue high byte, hue low byte, saturation %, brightness %]
Hue uses degrees; saturation and brightness use 0–100. Observed examples:
Color / brightness DP11 value Physically verified route
Red, 50% AABkMg== Developer-project cloud API
Red, 10% / 100% AABkCg== / AABkZA== Developer-project cloud API
Blue, 100% / 10% APBkZA== / APBkCg== Local gateway connection
Purple, 100% AQ5kZA== Local gateway connection
Separately, local Tuya protocol 3.4 control through the existing gateway worked on two bulbs using TinyTuya 1.20.0. Both visibly changed color and dimmed while retaining blue. This was independent of the phone’s controls.
Those local tests are supporting evidence, not a request to add a new LAN architecture to your app. Later local queries failed with TinyTuya error 914, so local reliability remains unresolved.
Requested guidance / possible contribution
The key question is whether the device-sharing API currently used by com.tuya2 can send raw DP11 for this product. Success through a developer-project API does not establish that the same endpoint is available with your app’s authorization.
If it is supported, would a change scoped to this product/color format be appropriate to expose normal light capabilities and preserve color when dimming? If it is not supported, that confirmation would help me pursue the correct integration rather than propose an incompatible patch here.
I’m happy to provide further sanitized results and test a proposed build on one bulb before expanding to the others.
Great to see you are using AI to spam this forum! If you would have read it instead, you would have known how to correctly request support.
It’s not possible. The developer platform shows more functions, but not all of these are available in the API that Homey uses. If it shows no specification or data points, it’s not compatible the regular way.
However, there is one solution: you can create Tap-to-Run scenes in the Tuya mobile app, that run an action on the device (e.g. turn on, turn off, dim to 50%). When you create a Tap-to-Run for each action that you want to use in Homey, you can then trigger these from a Flow:
Hi
I have 2 dehumidifiers in my home (Arete® Two 10L Dehumidifier/Air Purifier & Arete® Two 25L Dehumidifier/Air Purifier)
Both are connected to Smart Home. And connected to Homey Pro with the Tuya app. Devices are recognized and basic stats are available.
While basic data is exposed (humidity level, on/off) the status of the watertank is not.It is available is the device information but changes do not set a trigger. How does one keep track of the tank status in Homey Pro?
Thanks for the help
Hendrik
{ “code”: “fault”, “type”: “Bitmap”, “values”: “{\“label\”:[\“tankfull\”,\“defrost\”,\“E1\”,\“E2\”,\“L2\”,\“L3\”,\“L4\”,\“wet\”]}” } ] }
