Ok, so I noticed all the app updates- looks like you’ve been busy!!
I saw that the ‘input active’ has changed to ‘input 1 on’ or ‘input 1 off’, so I’ve set up a test flow with my Shelly 1 in the PIR scenario (as working previously) where:
When: Input 1 on
And: After sunset, before sunrise
Then: switch output 1 on
However I’m not seeing any status updates on the Shelly 1 input when I trigger the PIR. I had it working with CoAP previously and no network settings have changed, the other devices 3EM etc all seem to be reporting in realtime (ish).
Is there something I missed in the change from input active AND input is exactly “true” to input 1 on?
Thanks,
