[APP][Pro] Widgetkeeper - dashboards in your browser + custom widgets
Thanks for sharing - great to see it mixed with other app widgets too!
The media player widgets not being the same height really bugs me - am I the only one? :smiley: Could fix that.
Isn’t that how you have the unit set up? :slight_smile:
I’d rather not do too much unit conversion in the widgets. But I get that it’s confusing that the settings assume Celsius.
I know Homey uses Celsius on the backend, but it then converts to the correct unit based on your location. Since I live in the USA, it unfortunately shows Fahrenheit. I’m fine with Celsius because I’m used to it, but it would be nice if the widgets matched the unit Homey is set to in our accounts. Right now they decide by location, and there isn’t a setting to change it.
Hi @Martijn747
Which app do you use for this? This image looks nice! :slight_smile:
Energy Flow
How can I start a new line for notes in the notes widget? Currently, the text just runs together in a single line.
Try SHIFT + ENTER
Works in flow cards, maybe also in the notes.
Already tried.
Nope
I’m probably lucky then :wink:
Just checked and SHIFT + ENTER also works on iOS:
Filling the note with a flow.
Then its not possible.
If I set the text using the flowcard, then SHIFT + ENTER also works in my case:
Strange, will try tommorow again.
Thx
As already mentioned, it works with any flowcard
Make sure to press both shift and enter at the same time, or, if available, use the shift hold function.
If not possible with your phone keyboard, you can create a pre-saved text (using an external keyboard, or PC/laptop) holding a new line, and copy/paste it somewhere on your phone and/or a widget.
When you need a new line somewhere, just copy/paste the pre-saved text holding a new line.
Something like:
Hi. I have a suggestion regarding colors—and it’s not just about the tile color, as shown in the screenshot below. Could you please add a “custom color” option to every flow card that allows for color customization? Ideally, the card would feature a “Color / Custom Color” selection; choosing “Color” would allow the user to pick from a set of predefined colors (as is currently now), while selecting “Custom Color” would allow to enter the user own value—for example, by using a color name (e.g., “Tomato”), a HEX code (e.g., “#FF0000”), or an RGB value (e.g., “rgb(255,0,0)”).
Zrzut ekranu 2026-11-19 025123
Sounds like a thing for 1.4.0 :slight_smile:
Build 1.3.2 is released for test:
  • Temperatures in °C or °F: a new Configure → Temperature setting. Automatic follows your Homey’s units, so a Homey set to imperial now shows °F everywhere: Device Values, the charts, Room Health, Value Matrix, Thermostat Presets, Weather Forecast and the rest. The temperatures you type in widget settings (Room Health’s range, an OK range, a chart’s threshold) are in that unit too. Thanks to @Martin_Martinez for asking.
    If you typed a °C threshold before and your Homey uses °F, type it again in °F. Room Health’s default range becomes 64–75 °F.
  • Tile shadows: the light-mode shadow under the tiles is no longer cut off at the bottom. Thanks again to @saschaeggi.
Great app. (One of) The Best!
I have a feature request for the “Value Matrix” widget. In the screenshots you’ve shared on GitHub, the humidity and CO2 values ​​are shown without any decimal places:
However, in my homey, they appear with decimal places that don’t add any useful information:
I assume this is because my sensors provide a float value rather than an integer.
Would it be possible to add a setting for each value to specify the number of decimal places to display? By this way, for example, temperature could be set to show 1 decimal place, while humidity and CO2 could be set to 0.
I think it would be great to be able to choose the default “not activated” colour as well as the other red, green, blue.
For exemple in dark theme it should the default “black”.
Or is there another work-around I missed?
I’m not quite sure I’m following you on this… using a Flow you can set a Device Values tile to any of these colours, including the default background colour of light or dark depending on your displays dark mode setting
Do you mean you want black and white added to the colour options?
