New app update ( TEST: 1.27.1 ):
Changelog:
NEW:
1: NEW: [Widget] cleanup old chats
2: NEW: [Widget] only cache for active widgets
FIXES:
1: FIX: App crash due to widget caching
If you find any issues , send a report via the mobile homey app
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
@Seinuh can you test the above?
Also, are you using the new dashboard widget or not?
Seinuh
October 4, 2024, 9:58am
962
Up and running
Let you know if it’s stable
@Seinuh I cleared all widget caches before starting so I expect it won’t give a memory error anymore. I forgot a check to see if the chat should be cached for a widget.
So Probably in your case you have no widgets or some but there are a lot of messages going trough the app. Resulting in a huge cache which Homey doesn’t like
Seinuh
October 4, 2024, 10:15am
964
It’s running stable 15 minutes so i think you solved it ! Sent you a small donation thanks @martijnpoppen
(Not using widgets at the moment)
@Seinuh Nice! Glad this fixed it
And thanks once again man!
@Bjorn_Schalks please try to repair the whatsapp device
It also looks like you created 21 widgets for WhatsApp. So my guess is the cache is full
Athom doesn’t have a way to tell if a widget exists. So I cleanup all old ones. But there are still 21 widgets in cache
So repair is your only option here…
@Bjorn_Schalks hmm that’s interesting
I’ll provide a clear all chats button
Frekel
October 4, 2024, 8:33pm
970
==== moved to the correct thread ====
@Bjorn_Schalks did you try a repair?
@Frekel sorry I don’t really understand your issue. Is it a WhatsApp issue or a find my apple issue?
@Bjorn_Schalks i Will try to create that flush button today. In the hope that will work
Frekel
October 5, 2024, 8:00am
975
@martijnpoppen Sorry. Was as “Find my Apple” issue. Moved the message to the correct topic!
New app update ( TEST: 1.27.3 ):
Changelog:
NEW:
1: NEW: add clear widget button to device
FIXES:
1: none
@Bjorn_Schalks Please use the button as shown above
@Mikl see above update for the clear chats button
Mikl
October 5, 2024, 3:40pm
978
Hello @martijnpoppen !
Thanks for the addition!
I see that after a flush of the conversation, authentication is required again:
Also, it would be nice to be able to do the action from a flow as well.
By the way, very good idea to have added the button in the device
@Bjorn_Schalks sorry but in that case there’s not much I can do unfortunately. But then you have to remove the device and add it again
I’m really sorry about that
Edit: are you aware of this : [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
Hi Martijn,
FYI.
Not that I had an issue with the Whatsapp Widget but I tried the button anyway. It is working for me
Rogier
@Mikl yes I agree however this is the best option as this also clear unwanted widgets and caches. I’ll fix that as soon as athom make it possible to decide which widgets are destroyed. Until then i keep it like this to prevent issues like others have with crashing apps
