New app update (
TEST: 3.0.6):
Big stability release. Updated to the final WhatsApp SDK release candidate (rc10) — first SDK update since November, packs 5+ months of upstream work. Combined with internal fixes targeting the high-CPU and “future messages” crashes some of you have been reporting since last releases.
Changelog:
NEW:
1: NEW: WhatsApp SDK update to 7.0.0-rc10 (final release candidate)
2: MAJOR: Update app to NodeJS 22 (requires Homey v12.9.0+)
3: Memory improvements, prevent app to crash on load. Cache became to big and caused CPU/RAM issues (going back to version 1.39.2 only possible with repair)
4: Add new condition flowcard - Text Starts With …FIXES:
1: FIX: high CPU usage and crashes caused by “future messages” pile-up
2: FIX: reconnect storms with overlapping reconnect attempts
3: FIX: device store filling up over time
4: FIX: 30 second delay on sending messages when the device was reconnecting
5: FIX: stale state surviving a logged-out / clear-session event
6: FIX: infinite query timeout causing memory growth
7: FIX: pre-key cleanup at startup could crash on installs with very large stores
8: FIX: parsing LID to phonenumber (SDK v7) (phonenumbers were encrypted this fixes it)
9: FIX: Poll card now only has 2 required items
10: FIX: Pairing issues
11: FIX: Text condition
12: FIX: reply Code token (due to LID parsing this got corrupted)
13: FIX: issue where loaded state was too old and instance tries to load 2000+ messages which are no longer relevant
14: FIX: “Waiting for this message” — when WhatsApp asks for a retry of an older message, we can now answer it instead of leaving the sender stuck
If you find any issues, send a diagnostic report
Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
Via Homey Mobile app:
More - apps - WhatsApp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Via Homey Webapp:
Settings wheel bottom left - Select WhatsApp - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
Don’t want to be part of a test version? Install the live version → WhatsApp | Homey
