[APP][Pro] Vision Security
New app update (test: 2.0.15 ):
  • FIX: ZM1601 battery status
  • Updated zwave library
@Ton_van_Rijnsoever hmm, really weird. I’m using the same way as the previous developer. Also it works for @Wout_van_den_Dool.
@Ton_van_Rijnsoever Could you try re-adding the device?
So today I got a log. I think from you @Ton_van_Rijnsoever.
Which says: [ManagerDrivers] [ZM1601] [0] - Battery: false
Which indicates the battery is not found. Will check what I can find for that.
Here also the same. No battery. Rest is :white_check_mark:
New app update (test: 2.0.16 ):
  • FIX: measure_battery pollinterval for ZM1601
If this doesn’t work can you send a new diagnostic report? :slight_smile:
I’m wondering. Is there an option to add the device as secure/insecure ?
It seems like the device is locked somehow and BATTERY status can’t be read.
New app update (test: 2.0.17 ):
  • FIX: changed requireSecure for ZM1601
I can only add it secure
Test again moment (did not see 17 and 18)
New app update (test: 2.0.18 ):
  • OPT: add battery info to ZD2102/ZP3111/ZP3102/ZG8101
Including unsecure is working. All the rest is working but battery is still ? (In 2.0.18) for the zm 1601
New app update (test: 2.0.19):
  • OPT: change associationGroups for ZM1601
@Peter_Peter can you send an diagnostic report?
Done
Thanks, seems like the same as Ton had. Battery: false
Can you try V2.0.19?
Done and sent new report with 19
@Peter_Peter can you check this page? https://developer.athom.com/tools/zwave
It should give information abouut your ZM1601
Yess i know. What do you want to know?
Are there any logs or battery information. As far as i can see your device doesn’t respond with a battery so Homey cannot pick it up
I take a look
