[APP][Pro] Vision Security
Yes Will check tomorrow !
Have a Nice evening
Hello
As for me, new test this morning :
  • Vision security beta 2.0.9
  • Homey 5.0.0
  • ZM1602 EU-5
The parameters are OK : I tried siren only / strobe only / siren+strobe and both are OK ! I also tried the “alarm auto stop” parameters and it is OK ! I don’t know why it is working for me, not for @Heronimus ?
My only remaining “problem” : in the action cards, I dont manage to understand the difference between “turn siren on” / “Activer” (the same with “turn siren off” / “Désactiver”).
@kietu
Oh that’s a good sign, let’s wait for more people to check that, maybe it does work with 2.0.9 :smiley:
Yeah I saw those too and i think it’s a duplicate. I’m not sure about that. Do they have the same behaviour?
Regarding the duplicate action card: That one was Patrick’s worked out version on my idea to make different alarm-actions possible: Only strobe or with siren. It must be somewhere in this forum. Nevertheless it never worked for me.
Verified that i’m using version 2.0.9
Set Siren Strobe mode to Strobe only.
Waited 5 minutes.
Still siren with strobe.
@kietu : Maybe we have different firmware / hardware versions?
Firmware version: 24
Subversion : 7
Firmware Version 1: 5
Firmware Subversion 1: 1
Firmware ID: 5633
Hardware version: 2
Speaking for myself, i think a working battery meter is more important than the strobe / siren option.
Thanks.
Hello
As soon as I change one parameter (siren strobe mode OR alarm auto stop), the red light is blinking 1 time, to confirm that the device has received the new parameter.
My informations are slightly different from yours (but I have ZM1602 EU-5, and you have ZM1601 model) :
Firmware version: 15
Subversion : 10
Firmware ID: 5634
Hardware version: 2
Regarding this function, I would suggest to have an action card to MODIFY the parameters in flows ? One action card SETALARMMODE(option) and another SETDURATION(option) ?
I’m not a specialist in Homey (only 1 year of usage), but I think it would be more “logical”
I have the idea to make the device blink when my house is under surveillance, and to make it blink AND ring when an alarm has been detected. But it is not urgent at all !!! Priority to make parameters work for all devices (ZM1602 and ZM1601 !) :slight_smile:
Crap, I replaced my Vision Security Siren with the Aeotec Siren as I did not expect the app to be compatible with version 5 ever again. Anyone living in the Netherlands that still want to have a way discounted siren let me know :slight_smile:
In ‘Patricks version’ i did see the red light blinking 1 time at a change. In the new version i don’t get this confirmation. Which make me think this is the reason for the problem; the change is not received.
Hi… I appreciate your help. Will there come a update for the Homey5.0 update? I can’t use:
Battery Operated Siren
Thx in advance.
I’ll check the parameters/settings guys.
I agree we can make improvements. But indeed first lets have all the stuff working.
I’ll work on the app tonight :slight_smile:
And thanks for all donations! :smiley:
@Shadow345th
Hi ,
I took over this app. So if you read a few posts back you’ll see I made an updated version for V5 in the test version of the app (Vision Security App for Homey | Homey)
If you want to be past of the test group, you can install the test variant and see if it works for you :+1:
Great news! I noticed the transfer to your name and send you private message to see if it was true.
Yes! I’ll test the app to see if it works!
Just installed v2.0.9 and i can confirm that my garage door sensors work like a charm!
Thanks @martijnpoppen ! You did a great job by fixing this in such a short time, without having a Vision device!
I hope the users will donate to keep up the good work!
Thank you very much for helping us out.
@ all, please consider a donation when the final is there. The man doesn’t even have a Vision device by himself. So he does it all for us and the community.
New app update (test: 2.0.10 ):
  • FIX battery status for all battery devices
New app update (test: 2.0.11 ):
  • FIX ZM1601 settings
New app update (test: 2.0.12 ):
  • FIX: ZP3102 alarm_tamper & generic
New app update (test: 2.0.13 ):
  • FIX: ZP3111 humidity/temperature/luminance reporters
  • IMPROVE: ZP3102 temperature
  • FIX: ZD2102 alarm_contact & alarm_tamper
  • IMPROVE: ZG8101 alarm_contact
Feedback for @MartijnPoppen : YES!!! :slight_smile: The setting Strobe only / Siren Strobe works now. Battery status (fixed in 2.0.10) doesn’t work yet. Same issue when I remove the device, and add it again.
Yess Great!!! Only strobe or Siren works her too Great. Battery status not working but very very happy sofar!!!THANKS
@Heronimus @Peter_Peter That’s good news!
I’ll check the battery status. For the ZM1601
So made a list with all issues/findings.
I hope this is correct. So we can keep track of things :slight_smile:
ZD2102 Door/window sensor
- STATUS UNKOWN
ZP3111 4in1 sensor
- STATUS UNKOWN
ZP3102 PIR motion sensor
- STATUS: IN TEST
- IN TEST: Fix generic alarm & alarm_tamper (found by @joenoo)
ZG8101 Garage door sensor
- STATUS: WORKING
ZM1601 Battery Operated Siren
- STATUS: IN TEST
- TO DO: fix Turn siren alarm_on/alarm_off vs on/off (found by @kietu)
- TO DO: fix Battery monitor (found by @heronimus & @peter_peter )
- FIXED: Settings are working
ZM1602 DC/AC Power Siren
- STATUS: IN TEST
