[APP][Pro] Virtual Drivers - Monitor anything with custom virtual devices
Virtual Drivers is a utility app designed to help you track, visualize, and act upon data that isn’t natively exposed by your existing Homey devices. By creating virtual sensors, you can use Flows to “push” values into them, enabling you to see custom data directly in the Homey UI and track it over time in Insights.
Key Use Case
Have you ever wanted to monitor a value that your device calculates but doesn’t show? Or perhaps you want to aggregate data from multiple sources into a single “sensor”? Virtual Drivers allows you to create these missing links. Simply create a virtual device and use a Flow to update its value whenever your source data changes.
Available Drivers
• Virtual Number: A versatile sensor for any numeric value. You can customize the units (e.g., liters, lux, kg), set the number of decimals, and define min/max ranges.
• Virtual Boolean: A true/false sensor where you can customize the labels for each state (e.g., “Open/Closed”, “Active/Inactive”, “Locked/Unlocked”) to make the UI more intuitive.
• Virtual Power (W): Specifically for monitoring power consumption.
• Virtual Temperature (°C): For tracking custom temperature points.
• Virtual Battery (%): Monitor battery levels, useful for devices that only report status via third-party APIs.
• Virtual Button: A simple on/off switch for triggering flows or representing a state.
Main Features
• Flow Integration: Every driver includes “Set value” actions, “Value changed” triggers, and “Value is…” conditions.
• Insights Support: Because these are treated as standard sensors, all your virtual data is automatically logged in Homey Insights for beautiful graphing.
• Customization: Tailor the labels and units to match your specific needs.
How to get started
  1. Install the app and add a new device.
  2. Choose the Virtual Drivers app and pick the type of sensor you need.
  3. Configure any custom units or labels in the device settings.
  4. Create a Flow: When [something happens] → Then [Set value of Virtual Device] to the tag/value you want to monitor.
Is there a reason to use this app compared to Advanced Virtual Device in Device Capabilities?
Yes.
:smiley: so which is it?
Have you tried this app? It’s about 10x faster to use on your device because it’s already pre-defined. But no one is forcing you to do it, do what makes you happy.
Hi Michal,
Can you add a Virtual String Driver? This would come in handy to send commands to my Android TV streamer (using MQTT from my TheHomeRemote tablet).
In the meantime, you can do this with Advanced Virtual Devices from the Device Capabilities app. Just create an AVD and add (multiple) text field(s) :wink:
Hello, sure, it is here:
Approval for release may take time, so you can use test version meantime.
Thanks Michal, it works indeed verrry fast! And 1.0.5 is already released as well! :tada:
Indeed, AVD is very versatile, and I use it with great pleasure.
But templates provided by this app are more robust (you can recreate them on the fly).
I have the need for a virtual 3-phase breaker/power meter with on/off with the following attributes:
  • measure_voltage.L1, measure_voltage.L2 and measure_voltage.L3;
  • measure_current.L1, measure_current.L2, measure_current.L3;
  • measure_power.L1, measure_power.L2, measure_power.L3;
  • meter_power.L1, meter_power.2, meter_power.L3;
  • meter_power (would contain the total of the 3 phases)
  • measure_temperature
  • onoff (used as a breaker switch. Those devices tend to have a software button, so they do need a ‘real’ physical breaker with handle next to it)
The L1’s could be used for 1-phase meter, too. The L2’s and L3’s would only be valid for 3-phase meter.
Many thanks.
I have created an AVD template for you:
Just goto the Homey app, create a new AVD and pick the “create from template” option.
Now select the 3 Phase Breaker:
You’ll need to refresh the Templates since i just made it.
Press Select:
Perhaps change the name and press Use this Template:
It might take a moment, but your AVD will be created with all the requested fields.
:partying_face:
Now, you might need to setup the Total Energy Field by selecting the right device:
Have fun! :wink:
(Oh, and first update the DC app to the current live version. The refresh button in the AVD templates was almost non-pushable).
Virtual Drivers v1.0.6: new Virtual Thermostat
This release adds a new device, the Virtual Thermostat. It behaves like a real thermostat, but you control it from your flows, or let it follow your real thermometers.
What it can do
  • On/off and mode (auto, heat, cool, off)
  • Target temperature (5-35 °C) and measured temperature
  • Actions: set measured temperature, set target temperature, increase target temperature by X, decrease target temperature by X
  • Conditions: measured temperature is between, target temperature is between, measured temperature is below target, measured temperature is above target
  • Triggers: measured temperature changed, target temperature changed, measured temperature reached target
The two “changed” triggers also give you the other value as a token (the target in the measured trigger, the measured temperature in the target trigger).
Link real thermometers (no flows needed)
You can link one or more real thermometers to a thermostat, for example all rooms on a floor. The thermostat’s measured temperature then follows them automatically.
  1. Open the Homey app and go to More, then Apps, then Virtual Drivers, then Configure.
  2. Tick the thermometers for your thermostat (they are grouped by zone).
  3. Choose how to combine them: average, lowest or highest, and press Save.
Without linked thermometers you set the measured temperature yourself with the “Set measured temperature” action.
Good to know
  • Linking thermometers needs the Homey API permission, so the app now asks for it.
  • The app now requires Homey 12.9.0 or newer.
Questions and feedback are welcome in this thread.
I like the virtual thermosstat. Use case: The airco’s have way to many settings and often the user is lazy, and turns the house in a refrigerator or oven, because the last person did so.
Now i can create a virtual thermostat with an on and off button. They can see the temp on the tile and set it, but also, when the airco is turned on, i can set the temperature to sane defaults.
But now it is winter. So probably, when the airco is switched on, it is in heat modus. A little problem, when it is turned of, the virtual thermostat switches back to auto.
So just a littje feature request: If i turn it to heat, then turn it off, and on again, it switches back to automatic. A setting for the virtual device: keep last heating mode, would be very helpfull.
Thanks for explaining the use case! I’ve added a “Keep last heating mode” option to the virtual thermostat’s device settings in v1.0.12.
When enabled, switching Heat → Off → On restores Heat instead of Automatic. It also remembers Cool or Automatic, including after an app restart.
The option is disabled by default, so you’ll need to enable it in the virtual thermostat’s settings once the update is available.
Unfortunately, the review is taking a long time, so it is currently in the testing phase.
You are the best!
This works really well (installed the 012 version)
Is there a way to put the mode on the tile? Than you know you turn the airco on in the right mode.
