[APP][Pro] Tuya Local
I’ve managed to get an Elko Smart Termostat (WiFi) connected, but its reporting the temperature using 2 digits for the fraction. Is there any chance you can add 100 as a temperature divisor? The current option is limited to 1 or 10.
Hi Danny
Yes — I’d recommend it. The app connects to the device, so it needs the address to stay where it is. If your router hands the device a different IP later, the app keeps knocking at the old one and the device goes unavailable; the log then shows EHOSTUNREACH for that address.
The cleanest way is a DHCP reservation in your router rather than a static address on the device itself — Tuya devices generally don’t let you set one anyway. On a Fritz!Box it’s the “always assign the same IPv4 address to this device” checkbox in the device’s detail view; other routers call it a static lease or address reservation.
If it does happen, nothing is lost: look up the new address in your router and correct IP address in the device’s advanced settings. The local key stays valid — that only changes if you reset or re-pair the device in the Tuya app.
Glad the lights are working
Andi
Please try the newest TEST version and let me know if it works: Tuya Local | Homey
Thank you
Good evening, when I try to add a thermostat, after setting the IP, device ID, and local key and connecting. I see all the correct data (current temperature, set temperature, status), but when I try to save I get the error
invalid_setting_type
This is the DP cloud
ID:
Local Key:
Product: XH-CTW
Category: wk
UUID:
studio
DP 1 Power bool true
DP 2 TempSet value 100
DP 3 TempCurrent value 265
DP 4 Mode enum Manual
DP 6 ChildLock bool false
DP 12 Fault bitmap 0
DP 101 C_F bool false
DP 102 Heating_state bool false
DP 103 Ext_temperature value 890
DP 104 Days_Holiday value 1
DP 105 Settemp_Holiday value 15
DP 106 Hightemp_Protect bool true
DP 107 LowTemp_Protect bool true
DP 108 ext_temp_display bool false
DP 109 room_temp_compensate value -10
DP 110 room_temp_zone value 5
DP 113 low_temp_limit value 5
DP 114 set_temp_max value 35
DP 115 set_temp_min value 5
DP 117 power_state enum keep
DP 118 Prog_Type enum 2days
DP 119 Prog_Workday1 raw BgARhwARCwQT
DP 120 Prog_Workday2 raw EgATFgARFwAR
DP 121 Prog_Restday1 raw BgAPBwATCx4T
DP 122 Prog_Restday2 raw DR4TEQATFAAP
DP — switch Boolean true {}
DP — temp_set Integer 100 5–1220 step 1 ℃
DP — child_lock Boolean false {}
DP — temp_current Integer 265 0–1580 step 1 ℃
Hi Roberto
Please try the latest TEST version and let me know if it works now: Tuya Local | Homey
Thank you
Working perfectly. Thank you!
I had some problems connecting to the thermostats. Out of six, I managed to connect four without any problems; the other two took a bit of trial and error.
Everything works now.
I even managed to find the dual switch, which, for some strange reason, advertises a MAC address, but uses a different one online.
Overall, it’s a bit of a challenge, but I hope this is the end of the thousand attempts with apps that use cloud computing.
I noticed a small issue with the app. My router and access points reset overnight. I assigned all DHCP reservations to ensure the same ones, but the app doesn’t automatically reconnect to the devices when the network comes back up. In the morning, I restart the app and everything works again.
Weather station WIFIWEST500WT
I am trying to get this weatherstation working in my homey Pro. I have come a long way but i can’t get the datapoint mapping right.
This are the available datapoints
DP
Function / Name
Debug Value
Type
Scale (scale)
101
Indoor Temperature
251
number
0.1
102
Indoor Humidity
520
number
0.1
103
Outdoor Temperature
190
number
0.1
104
Outdoor Humidity
810
number
0.1
109
Atmospheric Pressure
10130
number
0.1
110
UV Index / Sun Power
0
number
1 (none)
111
Wind Speed
0
number
0.1
112
Wind Direction
“SW”
string
N/A (String)
113
Rainfall
0
number
0.1
114
Wind Gust / Extra
0
number
1 / 0.1
126
Comfort Status
“comfortable”
string
N/A (String)
This is the current data in the Tuya local app.
Most values look ok
The issue is that in homey the DP’s 112 and 126 are not showing a value. .
What would be the correct JSON setting to show these values in the correct way? That is een textstring.
For DP 112
For DP 126:
Sorry the table was not copied correctly
Hi Roberto
when the network returns, the app opens a connection to each device again. For devices on protocol 3.4 or 3.5 there is a key exchange right after the connection opens, and if the device doesn’t answer it — common while it is still starting up after a power cut — the app waited for a reply that never came. No timeout, no retry, and nothing written to the log. A device on 3.3 can end up in the same place: after several failed attempts the app tries the other protocol versions, and if the network comes back while it happens to be on 3.4 or 3.5, it gets stuck the same way. Restarting resets it to the configured version, which is why your mornings worked.
There was a second half to it: the stalled connection was left open, and these devices accept exactly one connection at a time — so it kept the device unreachable even for later attempts.
Both are fixed in 1.0.177. The connection attempt now has its own time limit, and a handshake that goes unanswered is closed and retried like any other failure. Timeouts also get a proper explanation in the log now instead of a bare error line.
I also added a flow action, Reconnect devices, which reconnects everything at once instead of needing one flow per device. You don’t need it for this bug any more, but it is handy on a schedule or a button after the network has misbehaved. The default, “offline devices only”, leaves working devices alone, so it is safe to run repeatedly.
Please check new TEST version if it works for you: Tuya Local | Homey
Andi
Hi Guus
Could you please provide the Cloud Lookup Table?
Thank you
Andi
Thanks,
I tried the suggested version, disabling the reset flows I had created. Last night, everything worked properly. I’ll keep monitoring the situation over the next few days.
I’d like to ask something about the heating systems: I can’t control the oscillation and power level from the flow, even though both exist in the local and cloud DPs.
Hi Roberto
Could you please provide the Cloud DP Table of the Heater?
Thank you
stufa bagno
DP 1 switch Boolean false {}
DP 2 temp_set Integer 30 18–45 step 1 ℃
DP 3 temp_current value 28 -9–79 step 1 ℃
DP 5 level Enum level_1 1, 2, 3
DP 8 shake Boolean false {}
DP 19 countdown_set Enum cancel cancel, 1h, 2h, 3h, 4h, 5h, 6h
DP 101 fenestration bool false
As said before the problem is in the flow that it is not possible to set it
Hi Andi, is this what you need?
Weerstation Guus in Tuya
DP 1 temp_current value -200 -200–600 step 1 ℃
DP 101 intemp Integer 244 -90–500 step 1 c
DP 102 inhum Integer 560 200–950 step 1 %
DP 103 ch1temp Integer 220 -400–600 step 1 C
DP 104 ch1hum Integer 700 200–950 step 1 %
DP 109 pressure Integer 10040 300–12000 step 1 hPa
DP 110 windspeed Integer 4 0–2500 step 1 kph
DP 111 gustwind Integer 5 0–2500 step 1 kph
DP 112 wd Enum W N, NNE, NE, ENE, E, ESE, SE, SSE, S, SSW, SW, WSW, W, WNW, NW, NNW
DP 113 rain_1h Integer 0 0–60000 step 1 mm
DP 114 rain_24h Integer 310 0–60000 step 1 mm
DP 126 com enum comfortable moist, dry, comfortable, na
DP 127 alarm Raw AX8AAAYAAn8AAAgA maxlen 128
DP 128 alert Raw ZQADAfT/pmYAAwMgAMhnAAMCWP5waAADAyAAyA== maxlen 128
DP 129 unit Raw AQACAAMABAA= maxlen 128
DP 130 battery Raw AAQBBAL/A/8= maxlen 128
DP 131 basic Raw fwIHAACABGVmZ2iBLw== maxlen 128
DP 132 alertup bitmap 0 maxlen 11
DP 133 datadisplay Raw ZQBmAGcAaABpA2oDawNsAw== maxlen 128
DP 134 rain Integer 0 0–10000 step 1 mm
Regards, Guus
Hi Roberto
Please check the newest TEST version: Tuya Local | Homey
Andi
I tried the new version.
The level is indeed present, but changing it doesn’t change the object’s behavior.
I tried to see how the cloud database changes when it’s changed from the SmartLife app.
The enumerator changes between
level_1
level_2
level_3
I wrote a flow that allows me to set only the level, but it never changes even though no errors are shown in the log.
I don’t know if this can be helpful, but on Tuya Developer Platform - Device Debug, the level has the following structure:
level Enum
“range”: [
“1”,
“2”,
“3”
Hi Guus
Please install the latest TEST version and try the new Driver: Tuya Local | Homey
Andi
Hi Roberto
Is the Heater on while you change the values?
Please check again with the new version: Tuya Local | Homey
Andi
