I just received the email alert too, with wayyyyyy too much (thousands) “Datas” used. My flow
only uses commands : 0 to 6 commands / per day. Which should add the same amount of “Datas”, right ?
I’ve seen your post regarding the Data retrievals and the “Polling is active” option.
Question : If I set it to NO, it will stop requesting Datas? (and ONLY send commands), correct ?
My use is the following : When my Zendure solar battery is over 90% charged, start : Charging Tesla (1 command), and Set Amper to 9 (2nd command). When Zendure Battery goes under 10% : Stop the charging (3rd command of the day).
Thanks for the help
