Actually don’t know :). But it should delete the files so you will need to redo.
Can you send a debug log.
thanks for responding!!
Met vriendelijke groet,
P. vd Berg
Allright. Thanks
d64799f7-4630-4dc1-8623-903e5731f158
I donate because you have created an assume APP and to say THANK YOU to you for doing this and spending the time.
I give you a thought of appreciation almost every time I use the APP.
Keep it up and THANK YOU! ![]()
Maybe a second donation will come your way…
I don’t see why this would only concern the Dutch.
I am Dutch and have donated multiple times to multiple developers (I don’t use Spacey Plan though, but saw your rather offensive remark).
Better address your remark (in a friendly way) to all users that never donate, rather than put a whole country away without any substantation…
Same as Henk. I don’t understand the way people have ignorant and offensive opinions about others. Donated many apps once they got certain features (that I up-front would communicate).
Thanks for feedback and we do not want to do a blame game who is the best att thanking each other or not :). Lets just focus on developing fun projects instead.
So I have so many projects going that its hard to focus on all of them. I have now made the repo public for this project. You can find it here
Pleas help out in development and we can make this awesome with more support and smart features.
As a user of a homey pro eary2019 i did need to pay for the dashboard function, youre widget did pul me over te line to buy it.
So far i am very happy with it!
I have a idea left to make the widget even more useful, but i gues someone els already mentiont it before.
But for me it should be very useful if i can place a thermostat in a room and change the set temperature.
New version soon up. Mostly bugfixes.
A question however. I have a android tablet Android 10 running last version of Homey app. Spacey Plan do not even load there. Is it more of you that have this issues? Have more modern Android where it works great. I do not get any message or any feedback at all.
I will try to make some time to make some more updates but cant promise anything. Have so many projects running.
@Ludvig
At first thank you for this great app!
I have a new lenovo android tablet and there it loads the app and the map quick.
But after the update i have alot of problems with switching devices on and off. If i turn a device on via the button on the map it immediatly toggle from on to off. So it looks like if you tap on the icon it reads it as 2 taps so it turns the device on and within a seconde off.
Also the color switch on the icons doesnt save anymore.
I allready deleted the icons and add it again, but still have the same 2 problems.
This happend after the update, yesterday it all works fine.
Hope you can fix this.
Diagnotic report code:
a43f152d-f775-4aa7-a78e-0b9539c92157
Gaahh these things are so annoying. I have Ipad, Iphone, Samsung Phone, Google Tablet, Raspery PI with Android etc etc and on all of these the double klick is not happening. Your diagnostics shows nothing since its “expected behaviour” or its just on off. So it will not give an error. I think I will have to add some more debugging outputs to be able to capture more of these things. So will do that.
The Settings part I will check. I havent changed anything in the code regarding that but since it do not even work on off my older tablets there must have been changes in Homey APP or OS so maybe there is something strange with saving as well.
@Ludvig
Aaah that seems frustrating as a developer.
If click on install again on the homey app site, will it reinstall the app again with a fresh install? Maybe something went wrong with updating the app on my homey. 2 weeks ago my philips hue app als wasnt working after a update.
But if i click again on install on the homey app site, will it also delete the whole map i created?
If you have it installed and click again I actual think nothing happens at all. Or if it actual installs agains nothing really happen I would guess. If you uninstall it and then install it I think it will loose all settings and stored files. So maps would be gone completely. Since we still are in pre beta stage somethings that is a good option to get a fresh start with the latest stuff.
So the best is to uninstall the app and add everything again?
You dont have the problem it goes on and off if you switch a device on with the app?
Running on Samsung Tab S9+ @ Android15 running fine.
I completely removed the Spacey plan app and the appdata from my Homey last night and reinstalled it.
I set everything up again after the new fresh installation, but still the same problem. When I turn on a lamp via the floor plan, the lamp turns on and immediately turns off again. So it reads a single tap as two taps.
I’m afraid it’s due to the update, because the problem started as soon as the app was updated.
Hopefully you’ll find time to solve it soon, it’s a great app!
If you switch a light on in de homey app does it stay on? If not could it be that that particular light is switched off in a flow?
Just thinking with you.
@Rogier_Verheugen
Good thinking, but that is not the problem.
Just tested it, switcht the light on with the spacey plan app and it goes on and off. And after that i switcht the light on in the homey devices section and than the light stays on.
Looks like a problem in the spacey plan after the update.
Have anybody else also this problem?
Mine was working fine, but now I just see a white screen in the widget with no picture and none of the accessories I had there.
When I add a new picture with accessories, I can see it correctly.
So it seems like there might be a problem caused by one of the recent updates. Restarting doesn’t help. Removing and re-adding the widget also doesn’t fix it. ![]()
