[APP][Pro] Network Visualizer - See how your devices really reach each other, and where the signal struggles
Great app :+1: but have a side question : how to remove ghost devices ?
In developer tools ghost node does not show. Only in this app .
Also my two satellite bridges , do not work on zigbee as earlier posts also states. Maybe someone from homey could comment on that ?
Hi Arve @Arve_Bjornerud
I’ve been having a problem with the Thread/Matter network map widget timing out 9 times out of 10, like so:
This screenshot is from my iPhone 14 Pro Max on iOS 27.0.1 and it also happens on my Fire tablet 11 Max too. Hoping you might be able to shed some light on this issue please?
Diagnostic Report run just after the above screenshot: d13679f9-4337-40ff-9e02-31f127d5e258
Am i understanding correctly that this only works for the Homey Zigbee network? So it can’t be used if you use bridges like Philips Hue Bridge?
Yes, correct. It will still work, but only show directly connected devices. The Hue bridge also doesn’t expose such Zigbee data, so it won’t be possible
After a bit back and forth with the App Store crew the app is now live :partying_face:
Splendid news :tada:
I’m curious about how the Thread/Matter map is constructed. For example, one of my Switchbot locks, a matter over Wi-Fi device shows as bad, -89db. Yet, my Unifi network shows the link for the past 12 days or so as good in the -65db range. Does staleness factor in?
I trust Unifi more at this point, and the lock operates properly no matter if I use Homey, Apple, or Switchbot. No delays.
My Thread/Matter map still refuses to load, just keeps timing out. It used to work just fine, I don’t know why it stopped working, the Zigbee map still works perfectly well.
That could just be because they are seeing the signal strength in the opposite directions of transmission, they each report the strength of the signal they receive from the other device. If that makes sense.
Hi @Drako74, thanks for the report and the diagnostics, they showed exactly what was going on.
To draw the Thread map, the app asks each Matter device about its connections. Some devices, especially battery-powered ones, can take several seconds to answer or don’t answer at all. The app waited for all of them, which often took longer than the dashboard widget is willing to wait, so it timed out.
I have a fix ready. The widget now waits only a few seconds, draws the map right away, and uses the last known answer for any device that’s slow. A small “Updating…” shows in the corner while the slow devices answer, and the map refreshes itself once they have.
You can see the changes here:
I’m away from home right now, so I’ll test it when I’m back and then release it. I’ll post here when the update is out.
Quick update on Z-Wave: the app can only show Z-Wave as a star, with every device joined straight to Homey. Homey doesn’t let apps read the real Z-Wave mesh, meaning which device routes through which.
I’ve asked Athom to give apps read-only access to it:
If you’d like to see real Z-Wave routes in the app, please add a comment or a :+1: to the issue. The more people ask, the more likely Athom is to look at it.
@F3006 Hi! A ghost is usually left behind by a device that was removed, or that re-joined the network with a new address. It isn’t a real device, so there’s nothing to delete in Homey. The app only draws it so you can see that the routing table is out of date.
  • Usually it goes away by itself. The Zigbee controller drops old routes over time. Restarting Homey, or the Zigbee network under Settings → Zigbee, usually clears them sooner.
  • If its name looks like “0x1234 · Kitchen lamp?”, the route probably still belongs to that device. Homey’s own record of the device’s address is what’s out of date. If that device acts up, re-pairing it usually fixes it.
  • To just hide them, tap Stale routes above the map so it turns off. The dashboard widget already hides them unless you turn on “Show stale routes” in its settings.
On the satellite bridges, I can’t help much: that’s down to how Homey handles them, not something this app controls. Hopefully someone from Athom can comment.
@Arve_Bjornerud / @DaneedeKruyff
I have a question regarding the Zigbee network map. It shows information on the strength of each upstream connection in the mesh network. So between a device and its parent. If I understand correctly, this is based on the TX and TX Error rate values that Homey records that are also visible in the Homey Developer Tools (I see the same values over there).
My understanding of these TX and TX Error rate values is that they apply to the communication between Homey and the device. So the downsteam communication: how many messages Homeys sends to the device and which percentage of them did reach the device. Not the other way around, as the Zigbee network map suggest.
This seems to align with what I see in the Homey developer tools: there is very little communication initiated by Homey to battery powered devices, like door sensors and scene buttons. My assumption is that most seem to relate to the pairing proces, as the TX values are low and remain stable afterwards. Most communication regards the receiving of measurement values (represented by the RX value).
Is my understanding correct? And if so, how does the Zigbee network map get the TX/TX Error rate values for the upstream link?
I was asking myself too why just consider only TX values and neglect RX values. With the errorrate percentage I am not to happy too. 50% of 10 is 5 but from 10000 it‘s 5000 which seems much more worse.
Hmm, why did I miss this one ?
Love it. And as expected, by Zigbee network is quite nice
But my new Sonoff S60 smartpulg seems to have an issue.. It’s on the same desk ais my Homey Pro ? maybe 80 cm away. And it looks like it’s taking two devices with him in his fall…
Don’t mind the ‘Inbouwdimmer Pro’ it’s not connected at the moment..
