@JohanP Yeah, tasks that were created before the update with due date’s are broken. New ones should work
Thanks for testing!
Confirmed: creating tasks with duedate from flows work.
Tried to remove the title from the widget but it doesn’t seem to save the setting ? Title stays visible ?
When I go back to the settings it’s still ‘On’ ?
@JohanP Sorry, forgot to reply. The title setting is a setting of Homey itself and has nothing to do with the actual widget. The widget always shows the name of the list you’ve selected.
Yes, but normally you can choose not to show the title, that just doesn’t work ?
I have added two lists on my dashboard on my android phone. But when swiping to move up or down through the dasboards, the tasks are closed. I can uncheck them but it doesn’t seem to be the intended way of working.
@Kringloper Hmm, I’ve received more issues like this over at Android. I do however not own an Android device so I cannot test it, would you please create a screen recording of what happens exactly so that I can understand what happens?
I don’t know how to show my screenrecording file. I am only able to attach images here.
Scrolling is quickly seen as a short press (also on for example the spaceyplan widget). On the regular homeydevices in the dashboard you need a longpress to open it. Maybe closing an listitem only on a longpress will do the trick.
For example
-Upload to YouTube as private video, and share the link here
Hi @BasMilius
Can you confirm this is the right way to add a task to (specific person) ?
Because when I do this, my task list gets overcrowded with tasks, so many that Homey actually disables the app since there are too many requests.
Am I doing something wrong? Is this the correct way to use the yellow “task tag”?
@Borssie That creates an infinite loop, I should probably fix that. But what happens here is that your new task will be created when any kind of task is added, via both the dashboard widget or from a flow.
You should, for now, use another trigger or select a person from the widget…
I’ll look at that infinite loop this weekend ![]()
Great! Thank you for clarifying that! ![]()
For now I’ll take a different approach then
Have a good day!
@BasMilius Great app! Like the interaction, that you can add tasks from flow and the widget. And that the complete task still stayes Testing it on my iphone 15 pro works wel, but testing it on a very old ipad air 2 doesn’t show the widget. Have installed the latest ios and homey app. iOS 15.8.7 homey 13.0.0.
Is this ipad to old for your widget or is there something you can do?
@Robinjo I have the feeling that that i(Pad)OS version is too old, or at least, has a version of WebKit that is too old. I’ll do some research soon to see what newer WebKit feature I’m using to see if I can rewrite that.
Thanks in advance
Great app! Love the visual on the dashboard and the flow cards.
I have one feature request: in the flow card to add a task with a due date, please make it possible to set a “dynamic” date, for example via a tag. I want to create a recurring task with a due date in the future. Now I can only set a hard date within a card.
Would be very much appreciated! Keep up the good work ![]()
@Peter3 Thanks for the suggestion! I’ll look into it somewhere this week ![]()
Hey, great app and i really like its functions.
I have only one issue, if the list is a bit long and i need to scroll in the dashboard its checks off my items i touch.
Is this only me, or is it something to adjust in an update. Maybe it can be checked off in the round box in the left and not in the whole table
I have that same issue, its not you. Especially when swiping pages I accidentally tick or even delete items..
@BasMilius Just a question. On your github page I added a bug and created a pull request for it. Either you are simply too busy, or you haven’t noticed ![]()
Could you take a look? If you accept this way of working, I might be able to add the new flow card for dynamic due dates. I am really really looking forward using that! Thanks!
